Turbo nose panel
PostPosted: Mon May 07, 2007 2:08 pm    Post subject: Turbo nose panel Reply with quote
Does anyone have a pic of the inside of the nose panel off a 931 - specifically showing the grill attach points?? I've got a FG turbo nose panel from pefa-design for my NA and am not sure how the grills are supposed to hook up - I figure a peek inside a real one might help.
Gavin.
Tigger937
PostPosted: Tue May 08, 2007 7:35 am    Post subject: Reply with quote
Not sure I know what you're referring to, but if you mean the 4 small vents in the nose panel, there is just 1 small black sheet metal screw, top center of each of the plastic vents, that screws into a metal tab attached to the inside of the nose piece. On mine, I can see them from the front if I look closely. Let me know if you still need a pic.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
PostPosted: Tue May 08, 2007 3:48 pm    Post subject: Reply with quote
Yup, that's what I was referring to. If a pic is no hassle I'd still like to see it.
Gavin.
PostPosted: Wed May 09, 2007 12:29 am    Post subject: Reply with quote
See pichas here - http://www.924board.org/viewtopic.php?t=22088&start=13
