944 rear suspension in early 924?
Andrew NZ
PostPosted: Tue Jul 24, 2007 11:31 am    Post subject: 944 rear suspension in early 924? Reply with quote
Is it possible to fit 1983 944 rear suspension in an early (1977) 924?
The mounting points look to be completely diferent.
I've had a quick search but couldn't find an answer.
If this won't work, could the 944 spring plates be made to fit in my housing, as I'd like to have the adjustability if possible.
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
PostPosted: Tue Jul 24, 2007 10:16 pm    Post subject: Reply with quote
They are completely different, yes. I did it once, using a bandsaw to carve up the end mounts of the torsion bar carrier (from the 944 suspension) so they'd fit under the body. Alternatively, as you've noted, you could probably swap in the 944 spring plates, might be less work.
On the plus side, as I see you have a rally car, the early suspension is a hard-mount, eliminating the need for buying a lot of bushing replacements...
Andrew NZ
PostPosted: Tue Jul 24, 2007 11:07 pm    Post subject: Reply with quote
Thanks. Has anyone done this? Do they fit?
Andrew
1977 RX924 race car
PostPosted: Tue Jul 24, 2007 11:34 pm    Post subject: Reply with quote
i had 924 spring plates and i swaped them with the longer ones for the long aluminium arms. my car was an 83 ROW NA.
