isuras2
Posted: Thu May 10, 2007 3:59 am Post subject: Jetta Fuel Pump |
Would an early 90s VW Jetta fuel pump (both external and internal) work for an 80 924? _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
Posted: Thu May 10, 2007 8:19 am Post subject: |
probably not. _________________ Supercharger and EFI kits
cdubya
Posted: Thu May 10, 2007 1:00 pm Post subject: |
no idea about the jetta. But I have been running a volvo pump in my 931 for some time, and it has worked out quite well.
you might look up the specs for the jetta pressure range of the pump/system and see if it checks out with your car.
Putting in a wrong pump could cause issues other than poor performance, so you should be cautious.
also, the tech section has a listing of the interchangeable parts on our cars.
cheers,
colin |
Posted: Thu May 10, 2007 5:18 pm Post subject: |
If it's from an EFI Jetta then no way.
If it's from a CIS Jetta then possibly, but unlikely.
The problem is that the 924 system pressure is very high, even for CIS (which generally runs at a much higher pressure than EFI anyway). The fuel pump needs to be able to supply the full flow rate and still be able to maintain a pressure of about 100 psi. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Fri May 11, 2007 12:52 am Post subject: |
If you can swing $125, you can get a Pierburg external. . .good quality pump. _________________ Toofah King Bad
