Battery tray leak.
Goto page 1, 2, 3  Next
PostPosted: Thu Mar 15, 2007 8:57 pm    Post subject: Battery tray leak. Reply with quote
Wet feet so had a look and found this.
Started cleaning it up but got some fun ahead.
PostPosted: Fri Mar 16, 2007 2:58 am    Post subject: Reply with quote
Oh yeh, that's a job you'll be glad to be done with. Looks like it may have started in that enclosed channel like mine did. I had to cut open the channel and also remove the fender (wing) to complete the repair and found some rust to deal with on that while I had it off.
In case you missed the quick mention of it in my repaint thread, 31 pics of the battery tray repair start here -
http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/14dcre2&.dnm=f742re2.jpg&.src=ph
and 12 of the fender -
http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/14dcre2&.dnm=aabfre2.jpg&.src=ph
isuras2
PostPosted: Fri Mar 16, 2007 3:01 am    Post subject: Reply with quote
Did you re-weld (enclose) that channel or leave it open? From the pictures it looked like it is left open. I probably have the same repair.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Fri Mar 16, 2007 3:14 am    Post subject: Reply with quote
I left it open. Looks exactly like this -
http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/14dcre2&.dnm=7495scd.jpg&.src=ph
isuras2
PostPosted: Fri Mar 16, 2007 3:16 am    Post subject: Reply with quote
Is there a reason to leave open vs. re-enclosing it? Is the enclosed channel structural support? Just curious.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Fri Mar 16, 2007 3:28 am    Post subject: Reply with quote
I just left it ("for now" (,but in all honesty will probably leave it that way permanently)) for easy access in case of a future leak problem. Yes, for structural reasons you'd be better-off welding it back together, but I believe the wheel-well area repair is more important for structure. It's entirely up to you..
Benino
PostPosted: Fri Mar 16, 2007 5:38 am    Post subject: Reply with quote
thanks for the pictures smoothie. I was wondering what that channel was like on the inside. I have a battery tray repair job ahead of me.
Just as a note on something to look for with water leaking in from the battery tray. Both my 924 and my 931 (aside from the normal battery tray rust problem in the right front of the tray) had stress cracks in the left front of the tray just before and about where it starts curving up towards the heater fresh air inlet. Not rusted just cracks. Thats actually where the water was getting through on my 931. There were no actual rust holes.
ps. I hate battery trays! . . . actually I hate rust, but aren't those two words almost synonyms?
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
PostPosted: Fri Mar 16, 2007 6:04 am    Post subject: Reply with quote
Hey Smooth Dog,
Based on all you went through here, if you had a pristine battery area, what preventative steps would you take with it? I happen to have a can of seam sealant sitting in my garage. . .
PostPosted: Fri Mar 16, 2007 7:09 am    Post subject: Reply with quote
Top pics mate- exactly where mine is on the RHD version (battery on left)
PostPosted: Fri Mar 16, 2007 7:14 am    Post subject: Reply with quote
Well, knowing what I know now I'd try to get a look inside that channel for any signs of rust. Mine was apparently not painted, not undercoated, not anything inside there by the factory, so it's a great place for rust to start. Remove the battery and pull off those little plugs and get a look inside as much as you can (which won't be much of a look). You could also scrape off whatever seam sealer there is along the seams outside of the channel to see if there's any rust starting under it. If you find any at all, consider opening up the channel some to get a better look and access inside to do some cleaning, rust treatment, coating - no need to open it up as much as I did - maybe make an oblong opening removing the metal that the inspection holes are in that will give you enough room to see, fit in a brush, do some rust treatment, spraying, bodyfiller, whatever's appropriate. -Or just shoot some rust treatment followed later by undercoating in through the little OE holes, hope for the best, then do the full cutout and repair further on down the road if it becomes necessary. I found what looked like a minor seam problem a couple years ago, dealt with that, then this last fall was suprised by the much more serious rust in the same area.
In the wheelwell area, press in around that area that I cut out and replaced. If the metal behind is rusted badly enough, you'll hear it crunch and feel it move. In about a 2" diameter spot there behind the wheel, all I had was the factory undercoating which looked fine, but you could press in on that spot because the metal behind was rusted out.
Those areas of the fender and adjacent door jamb and body where I found rust seem to be common rust areas. You'll be able to see any damage at the bottom where road grit/dirt accumulates, but the rear of the fender where it's bolted to the door jamb is invisible until the fender is removed. I caught mine in time so a cleaning with naval jelly was all that was needed (followed by the PPG metal treatments, POR15, and undercoating), but as I recall, 924guy in Fla found his rusted through in that area to the point were some cutting, grafting and welding would be needed. Nice to know my right side is ok now, but I still have the left fender to wonder about..
PostPosted: Fri Mar 16, 2007 12:32 pm    Post subject: Reply with quote
Ok- I am trying to remove the LH wing, fender, mudguard.
I have all the screws off at the front and top.
I have one screw removed from the bottom at the back.
Before I start pulling at it - is there any more?
steeny
PostPosted: Fri Mar 16, 2007 1:52 pm    Post subject: Reply with quote
i assume you've looked here
http://www.924board.org/viewtopic.php?t=20669
for where to find all the fender bolts.
apart from that i guess you just have to pull carefully and hope.
good luck mate
1978 924 N/A
she's gone.....
PostPosted: Fri Mar 16, 2007 2:12 pm    Post subject: Reply with quote
Its the 3 at the back inside the that I couldnt see.
Thanks
PostPosted: Fri Mar 16, 2007 2:13 pm    Post subject: Reply with quote
These are the more hidden ones -
spect in http://www.924board.org/viewtopic.php?t=21535 wrote:
- the one on the bottom corner under the edge of the headlight, getting to by removing that black rubber piece that keeps a seal against the headlight.
Min wrote:
There is three buried in undercoat under the fender close to the door. Did you undo those ones?
Feel for 3 bumps aligned vertically, behind the fender and facing the rear through the undercoating. I had to scrape some of the undercoat off first to get a socket wrench on them. You can get an idea of where they are by the 3 holes shown in this pic -
http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/14dcre2&.dnm=bf28scd.jpg&.src=ph
PostPosted: Fri Mar 16, 2007 2:26 pm    Post subject: Reply with quote
I'll attack again it after lunch.
Got the headlight screw already thanks- 3 to go at the back.
Page 1 of 3
