Fuel Pump fuse rating
Aussie931
PostPosted: Fri Apr 06, 2007 1:16 pm    Post subject: Fuel Pump fuse rating Reply with quote
Hi all
Can anyone confirm what rating fuse should be used for the fuel pump circuit. The handbook says 16A while my Haynes manual says 25A. I have been blowing a few of the 16A ones and was wondering whether this is because I should be using a 25A or if there is a more serious issue with the circuit.
Happy Easter,
Aussie931
1979 Series 1 924 turbo
PostPosted: Fri Apr 06, 2007 3:04 pm    Post subject: Reply with quote
If you have only one pump, the external pump, then a 16A fuse is enough.
-But I'm pretty sure you'll have both the internal tank pump + external pump. You need the 25A for that. If you have a couple of wires running to the outlet of the fuel tank, then you have both internal and external pumps.
Aussie931
PostPosted: Fri Apr 06, 2007 8:08 pm    Post subject: Reply with quote
Thanks Smoothie. I have both the internal & external pumps so I will change over to a 25 A fuse.
Aussie 931
