931 vs. 924 auxiliary air valve
-nick
PostPosted: Fri Mar 23, 2007 4:40 am    Post subject: 931 vs. 924 auxiliary air valve Reply with quote
Anyone know why the 931 piece looks so incredibly over-engineered?
The valve I'm using with my EFI is either on/off. This can make the idle _really_ high when it's warming up. And when the valve clicks closed, it idles _really_ low until it warms up a bit more. So I'm looking into using the CIS AAV, which has a gradual movement of the disc based on temp (and electrical current).
I'm wondering if I can just use a simple 924/944 AAV in a boosted engine. I can't figure out why the 931 part is so chunky?
Alternatively, anyone have an extra 931 AAV to get rid of?
1980 931S
1991 964 C4 Cabriolet
PostPosted: Fri Mar 23, 2007 7:10 am    Post subject: Reply with quote
All I can guess is that the 931 AAV is designed to handle both vacuum and pressure while the 924NA's was designed with only vacuum in mind. I'd give the 924NA version a try personally. Then if it pops open under boost (it would most likely go at the electrical connector end), drill and tap for a strategically placed screw or two to hold that end on.
PostPosted: Fri Mar 23, 2007 5:57 pm    Post subject: Reply with quote
Have you thought of using the later VW type of idle valve, Nick?
There're a quite simple progressive-type design which could be adapted to your EFI system...?
The problem I have with the CIS AAV is that the open-closed range seems pathetically small. I my view, you want something with about three times as much range on it.
-nick
PostPosted: Sat Mar 24, 2007 4:58 am    Post subject: Reply with quote
I need something that is temperature operated. I would have to do more soldering and circuit board & wiring changes than I would like if I switched to an electrically operated progressive solenoid.
I give the n/a CIS valve a whirl first.
1980 931S
