Clocks should go tick-tock shouldn't they?
PostPosted: Wed Mar 28, 2007 10:33 pm    Post subject: Clocks should go tick-tock shouldn't they? Reply with quote
I had my clock, oil pressure and volt gauges out to fix up some cracks around the gauge cases. Now that it's all back together the clock no longer goes... I don't think I screwed up the wiring as it's pretty simple stuff, and have already checked the clock wires (all 2 of em). I couldn't find a fuse for the clock specifically (the oil and volt work fine still), so not sure where to look next. Anyone played with the clock much before...?
Gavin.
PostPosted: Thu Mar 29, 2007 12:50 am    Post subject: Reply with quote
On mine, the oil pressure and clock are on the same power line, so if that is connected, and the ground is connected, your clock has passed to the clearing at the end of the path.
Benino
PostPosted: Thu Mar 29, 2007 3:39 am    Post subject: Reply with quote
Try your hazard flashers. If they also don't work, then it's the fuse. they share a fuse.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
billson
PostPosted: Thu Mar 29, 2007 3:52 am    Post subject: Reply with quote
I had my clock out recently to fit a gauge bezel. Put it back in and it had stopped. Other gauges were fine. Turned out i blew a fuse - number 7 if I remember correctly Also the interior light and radio go through this fuse. 8amp fuse I think
1983 924 NA
Guards Red
Carrera GT bodykit
Larger VW throttle body
PostPosted: Thu Mar 29, 2007 11:53 am    Post subject: Reply with quote
Ahh, cool - thanks guys for the responses!
Billson, I also fitted some bezels whilst I was fixing the cracks - they look much better I think.
Gavin.
