Engine Knock - possible Exhaust leak?
isuras2
PostPosted: Fri Mar 16, 2007 2:57 am    Post subject: Engine Knock - possible Exhaust leak? Reply with quote
With the engine running, it sounds like knocking coming from under the valve cover. The tapets/valves are adjusted to within spec. Could the knocking sound be and exhaust leak between the manifold and head?
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Fri Mar 16, 2007 3:07 am    Post subject: Reply with quote
Could be that.
Arcing spark can be suprisingly loud and sound like a knock or loud valve tap, so check for that too.
Do you notice it just at idle with your face in the engine compartment? -Or can it be heard also while driving? How does the sound change under accelleration/load.
isuras2
PostPosted: Fri Mar 16, 2007 3:15 am    Post subject: Reply with quote
I would doubt it is arcing spark as I have not been shocked yet and the wires are about 1 year old (NGK wires). I believe it changes with RPM, but I haven't really been able to listen too much to it while driving because the exhaust out back is loud so other sounds aren't as noticeable.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Fri Mar 16, 2007 3:55 am    Post subject: Reply with quote
Well, since you already have a loud exhaust, just get a loud stereo and the noise will be gone!
In seriousness, though, my car makes a bit of valve racket too. . .probably sounds like imminent destruction if you have never owned a solid lifter car before.
PostPosted: Fri Mar 16, 2007 5:19 am    Post subject: Reply with quote
Good point, it might just be normal.
If you could hear it from the drivers' seat and it got much louder under load, then I'd've said bad connecting rod bearing. -And knock under load, but not at idle can be too-low octane fuel, too-advanced timing, and/or carbon build-up on the pistons-valves-head.
-But loud valve train noise (clicking/ticking) with the hood up and your ears right there is pretty much normal with the 924NA and 931.
Ouch. This was my 5000th post. I should get a hobby, eh?
Benino
PostPosted: Fri Mar 16, 2007 5:49 am    Post subject: Reply with quote
yup. My 924 made that noise even with a freshly rebuilt engine, valves adjusted, and new gaskets and seals everywhere.
the loud stereo solution "fixes" lots of problems.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
PostPosted: Fri Mar 16, 2007 5:56 am    Post subject: Reply with quote
Wait, isn't this your hobby?
PostPosted: Sat Mar 17, 2007 12:44 am    Post subject: Reply with quote
this might sound a bit crazy but check your alternator...start the car with the alternator / water pump belt off....listen if it still knocks. i tought my engine was shot...because the knock was near the tappets....but it turned out to be the alternator.
PostPosted: Sat Mar 17, 2007 2:42 am    Post subject: Reply with quote
Good point again.
A bad water pump will sometimes knock too.
isuras2
PostPosted: Sat Mar 17, 2007 2:58 am    Post subject: Reply with quote
I will have to try that next time I start it up. I wonder if getting a loud stereo along with the loud exhaust will help get rid of the rad. fan whine.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
