sparky
Posted: Wed Mar 07, 2007 8:52 pm Post subject: Just a quick gauge question :) |
Hey there,
Just a quick Q this time,
My 76 924 has one of those oil gauges in the center console, im not sure if the previous owner just dumped it in there, but either way I was wondering if there is a way to connect it so it works
PS: can someone with an early 24 post a pic of their engine bay please. Just need to check a few little bits out!
Cheers! _________________ When the checkered flag drops... The Bull$hit Stops
1976 Euro 924 (The 945) - Full 951 Brakes/Suspension
1998 Boxster with goodies
2002 3.0 Xtype 4wd sport |
leadfoot
Posted: Wed Mar 07, 2007 9:25 pm Post subject: |
Oil temp gauge or oil pressure gauge??
oil temp gauge requires a sender screwed into the oil pan, and then a wire connecting it to the gauge, plus a 12V+ power lead and earth lead,
Oil pressure is the same but the sender is screwed into the back of the head.
carbon fiber GT mish mash
sparky
Posted: Wed Mar 07, 2007 9:34 pm Post subject: |
Hey leadfoot,
I do beleive it is a oil pressure gauge, but I can confirm tonight.. but I am about 95% sure!
Is it possible if the sender unit is not there on my car? And if so, if it a big job to fit one to the back of the head?
Posted: Thu Mar 08, 2007 4:10 am Post subject: |
There is a sender/sensor screwed into the distributor adapter (lump that the distributor is inserted into that is bolted onto the rear of the cylinder head.
Cars that only have the warnng light on the instrument panel have a single sender, and cars with both the warning light and the pressure gauge on the center console will have a dual sender.
Look at the sender on the rear of the cylinder head, and if you have the single sender, you will need to buy the duel sender, and simply screw it in inplace of the single sender. If you have the dual sender, then you will need to check the wiring, and find out what is not there or not connected or defective.
Posted: Thu Mar 08, 2007 6:37 am Post subject: |
If/when you need to know how to hook-up the wires look here -
http://www.924board.org/viewtopic.php?t=19075&start=10
Chrenan has a nice pic of the dual purpose oil pressure gauge/light sender there too.
We'll hope yours is already there and with wires attached because they're tough to access. _________________ "..it's made in Germany. You know the Germans always make good stuff."
sparky
Posted: Thu Mar 08, 2007 8:16 am Post subject: |
Hey guys,
I do have the one with the single sender, and there are also no wires anywhere near the gauge for it to connect to.
I dont mind the challenge of getting it rigged up
Does anyone have a dual sensor that they dont need?
Cheers!!
Mark _________________ When the checkered flag drops... The Bull$hit Stops
leadfoot
Posted: Thu Mar 08, 2007 10:24 pm Post subject: |
Try posting in the car parts wanted section of the forum, there are also a few guys parting out cars at the moment and may be able to help you out...
Posted: Fri Mar 09, 2007 2:20 am Post subject: |
Sparky, this part is a major PITA to install. You may wish to consider a new one. . . _________________ Toofah King Bad
Neil924
Posted: Fri Mar 09, 2007 8:37 am Post subject: Re: Just a quick gauge question :) |
| sparky wrote: | Hey there,
Cheers! |
A 1977 Euro:
sparky
Posted: Fri Mar 09, 2007 11:54 am Post subject: |
cheers neil,
I can now see that i need a few little bits and pieces here and there to get everything right under my hood!
Pics you posted are really appricated! _________________ When the checkered flag drops... The Bull$hit Stops
