Later 5 speed swap
driver1
PostPosted: Sat Mar 03, 2007 5:22 am    Post subject: Later 5 speed swap Reply with quote
what all is needed to swap a 016/9 type into a '78 924.
I'm pretty sure that's waht I have, it looks like a 4 speed but, the end cover is a bit different and it's a little longer. Also, where are the ID numbers on these? The coupler shaft fits on both to.
endwrench
PostPosted: Sat Mar 03, 2007 7:09 am    Post subject: Reply with quote
It is essentially a bolt in.
Todd
driver1
PostPosted: Sun Mar 04, 2007 5:41 am    Post subject: Reply with quote
Yeah, it looks it would be but, would the shift linkage work?
PostPosted: Sun Mar 04, 2007 1:27 pm    Post subject: Reply with quote
you need the piece on the tranny that the shift rod slides onto, but hey guess what,,,,
all that is in the FAQ Tech section.
3 928s,
924guy
PostPosted: Mon Mar 05, 2007 1:32 am    Post subject: Reply with quote
fairly easy upgrade, unless you hit some stuck or rusty parts... good too have two people to stick the tranny back in , it can be a little hard to manipulate and get lined up right, but not impossible for one person to do with a decent jack and some patience.
you will loose a bit of low end torque, but you gain it back on the high end. the 5spd feels quite different than the four speed, take a bit of getting used too
make sure your donor tranny is from an n/a 924, turbo and early 944 unit has a larger shaft and wont fit unless you make an adaptor coupler
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
driver1
PostPosted: Mon Mar 05, 2007 5:22 am    Post subject: Reply with quote
Lizard, guess what, I did read the FAQ and it didn't say anything about a shift thingy to slide into.
Ther'e more info on the snailshell 5 speed than this one.
