fitting 944 plastic fuel tank
Goto page 1, 2, 3  Next
bruce76-924
PostPosted: Wed Feb 28, 2007 9:49 am    Post subject: fitting 944 plastic fuel tank Reply with quote
Hi guys,
I noticed in a few old posts that the question of fitting 944 plastic fuel tanks to 924s has cropped up more than once. Yes you can fit them, I've just fitted one to my '79 931 this weekend and I fitted one to my old 81 924 a few years back.
You do need to replace the crossmember with the late 944 bolt in crossmember and if you have a 924 then you have to make up new mounting plates for the trans mounts. If you have a 931 then as the transmission isn't mounted on the crossmember then it is easier. If you ae going to use the 944 tank, then get the tank, sender unit, cossmember and straps from the breakers yard together. As a guide I just paid £50 (UK) for my parts and spent all Sunday afternoon fitting it all.
If anyone needs more detailed info let me know. Oh yes great site, really can't believe I've been playing with 924s for all these yeas and never stumbled on you all before!
Cheers Bruce.
1976 924 LHD, full cage, semi tube chassis, 951 brakes, lightweight 951 body panels.
1.8t engine conversion with Holset turbo and 6 speed Audi gearbox.
steeny
PostPosted: Wed Feb 28, 2007 10:15 am    Post subject: Reply with quote
1976 924 LHD, Garrett turbo, 8 injectors, water injection, multiple intercoolers, 931 trans, 951 brakes, lightweight 951 body panels.
that sounds like fun.........
1978 924 N/A
she's gone.....
moone924
PostPosted: Wed Feb 28, 2007 11:00 am    Post subject: Reply with quote
Not to hijack but I'm going top be putting a 924S plastic tank on my 931 as soon as the lift in the shop is free. So I'm curious too...
Ryan Moone
New philosophy : one car project at a time.
PostPosted: Wed Feb 28, 2007 12:05 pm    Post subject: Reply with quote
Bruce, any more detail you could give would be great. I bet there's a lot of guys, including me, who would be interested.
Min
PostPosted: Wed Feb 28, 2007 1:26 pm    Post subject: Re: fitting 944 plastic fuel tank Reply with quote
I'm quite interested in that as well..... garrett turbo? which one? .. 8 injectors? fuel management? multiple intercoolers? ... how much boost? do you have dyno sheets?
Min
arx
PostPosted: Wed Feb 28, 2007 5:06 pm    Post subject: Reply with quote
FYI the 944 plastic tank is actually heavier than steel one. But of course -its also bigger and no rust problems anymore. Fitting is rather easy as bruce mentioned if you figure out ho to mount the transmission.
PostPosted: Wed Feb 28, 2007 8:18 pm    Post subject: Reply with quote
heck ~80 Liters is enough for me...tho i have a spare 944S tank.
bruce76-924
PostPosted: Thu Mar 01, 2007 8:19 am    Post subject: Reply with quote
Fitting the tank is pretty straightforward..........depends on which vehicle/transmission you have though.
On my 931 the gearbox isn't mounted on the crossmember and being a "snail shell" type box then the tank can even be removed with the trans in situ. The standard 924 and 924S need the trans removing first though. The original crossmember will need removing as it is welded in, then you can either weld in captive nuts or just drill through the chassis rail from the boot/trunk and then bolt the new crossmember in.
The plastic tanks are also bolted through the center, so I drilled 2 holes through the boot floor and used 10mm threaded bar to bolt the tank up. Using a combination of 944 and original tank support straps then the tank can be supported from underneath as well. The fuel pump will sit under the tank in the 944 pump shield which is also bolted to the retaining straps. The fuel gauge will need the 944 electrical connector splicing in to the loom and although the gauge will work it will read different as the new tank is obviously larger - the yellow warning lamp functions accurately still.
If your transmission was mounted on the crossmember then you need to weld in 2 flat mounting plates with captive nuts in for your trans mounts to bolt up to, this is also the best time to mount the accumulators if used. that's it really, exhaust back up, trans back in, drop the car back of the axle stands and fill up with fuel. No more rusty tank problems! I'll try to get some pics of the 931 this weekend and somewhere I still have the pics and templates of the crossmember modifications needed for the standard 924.
Failing that, if you're in the UK near Yorkshire I'll give you a hand with it, just drop me an email.
Cheers Bruce.
bruce76-924
PostPosted: Thu Mar 01, 2007 8:39 am    Post subject: Re: fitting 944 plastic fuel tank Reply with quote
Min
Min, how did I guess that you might pick up that little lot?!
The garrett is a hybrid, 8 injectors and fuel management....oh no, this is still CIS, 2 fuel pumps and 2 fuel distributors with the second set of injectors coming on at 3/4 throttle ( this was put together before megasquirt) No waste gate! When I last ran the car a few years back my boost gauge read 32 psi under full load and the engine was still pulling strong.
I'm just getting the car back out of hibernation and starting to take it all to bits to re-fettle it (house pojects, job changes and twin 3 year olds have held me back for a few years). It has been stood in too many bits for too long now so as it goes back together I'll take pictures and keep you informed. Reading what some of you guys have done to your cars has given me the push to get on with it.
Chees Bruce.
Chrenan
PostPosted: Thu Mar 01, 2007 8:59 am    Post subject: Re: fitting 944 plastic fuel tank Reply with quote
bruce76-924 wrote:
...this is still CIS, 2 fuel pumps and 2 fuel distributors with the second set of injectors coming on at 3/4 throttle ( this was put together before megasquirt)...
WOW!
PostPosted: Thu Mar 01, 2007 9:04 am    Post subject: Re: fitting 944 plastic fuel tank Reply with quote
That's gotta be 400 HP+ easily!
Min
PostPosted: Thu Mar 01, 2007 5:00 pm    Post subject: Re: fitting 944 plastic fuel tank Reply with quote
wow, ok now I need way better info, pistons? head? rods? what kind of exhaust? what kind of intake? more details on the water injection? ... do you have headstuds? how are you keeping the head down at 32 psi???? I think we're going to need pictures..... Sounds like a awesome little project.
Min
PostPosted: Thu Mar 01, 2007 6:49 pm    Post subject: Re: fitting 944 plastic fuel tank Reply with quote
yep !
steeny
PostPosted: Thu Mar 01, 2007 8:43 pm    Post subject: Reply with quote
i thought at 32psi these things would become a smouldering mess of scrap?
anyway, i third the vote for pics. too often we hear about pie in the sky dreams of such a setup, not often enough anyone has the balls or skills to got hrough with it.
1978 924 N/A
she's gone.....
bruce76-924
PostPosted: Fri Mar 02, 2007 7:15 am    Post subject: Re: fitting 944 plastic fuel tank Reply with quote
"wow, ok now I need way better info, pistons? head? rods? what kind of exhaust? what kind of intake? more details on the water injection? ... do you have headstuds? how are you keeping the head down at 32 psi???? I think we're going to need pictures..... Sounds like a awesome little project."
I'll spec out the car in full detail later on, but engine wise here goes......
1976 2.0 litre block and head ( head drilled and tapped to take screw in cis injectors), VW LT van pistons to bring the compression down, home made adjustable cam sprocket, custom ground camshaft, fully balanced crank and flywheel assembly, AP racing custom clutch assembly, Audi 100 exhaust manifold turned upside down so that the Garett turbo can be mounted high up on the front of the engine, twin CIS fuel distributors running 8 injectors, 9th injector manually operated for cold start, 2 radiators and 2 water pumps and far too much pipework!
Since you all asked it spurred me on to clear the garage out and drag the car outside this afternoon ( it's been hibernating in bits for the last 4 years) in order to take some pics. I'll ty to get them posted later on this evening but I guess I should stick them on the performance side the forum.
Cheers for showing a bit of interest in it, Bruce.
Page 1 of 3
