Slim Radiator Setup
flosho
PostPosted: Sun Jun 17, 2007 12:25 pm    Post subject: Slim Radiator Setup Reply with quote
I've been thinking about replacing the stock radiator fans, with either one bigger, slim fan, or two equal sized slim radiator fans.
Has anyone done this or have experience with this, or suggestions..
[This Space For Rent]
Chrenan
PostPosted: Sun Jun 17, 2007 12:33 pm    Post subject: Reply with quote
I've done it. Used a single Perma Cool 3000 cfm fan from Summit Racing, item number PRM-19008 if this link doesn't work:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=PRM%2D19008&N=700+4294924500+400006+4294838842+4294891681+4294775280+4294774135+115&autoview=sku
The thing that is great is the low amp draw combined with the high cfm, plus it is a very light fan. With a small extension to drop the lower mounting hole on the fan an inch, the holes in the perma cool fan will bolt up on the rad top and bottom. That will hold the fan in place very solidly. Then I used the supplied zip ties on the side holes of the fan to stabilize it through the rad core. I can post pics if you need them.
blown 944
PostPosted: Sun Jun 17, 2007 4:08 pm    Post subject: Reply with quote
I used a fan from a mercedes 420 sel 16" works great. I m working on a 944 though but I don't think ther's a differnce.
PostPosted: Sun Jun 17, 2007 10:07 pm    Post subject: Reply with quote
I have a single slim fan on the racecar, works great for that. Not adequate for street traffic jam usage, but would be fine for anything less than the Woodward Dream Cruise (10 mile 8 lane traffic jam/block party/cruise-in)...
Raceboy
PostPosted: Sun Jun 17, 2007 10:39 pm    Post subject: Reply with quote
Recently changed to new 16" slim fan on white NA-turbo and as Chrenan stated, great to see very low current draw combined with good cooling.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
flosho
PostPosted: Mon Jun 18, 2007 1:51 am    Post subject: Reply with quote
So all these fans are pretty much bolt in and reconnect the wires or is everyone running new wires and what not?
Chrenan
PostPosted: Mon Jun 18, 2007 2:45 am    Post subject: Reply with quote
My fan just came with 2 bare wires sticking out. I got an generic electrical connector at a parts store and used that to make a connection with the factory wires.
Min
PostPosted: Mon Jun 18, 2007 5:56 am    Post subject: Reply with quote
http://www.fordmuscle.com/archives/2003/02/electricfan/index.php
Min
Min
PostPosted: Mon Jun 18, 2007 6:11 am    Post subject: Reply with quote
isn't low amperage, but its a 16 inch fan from the junkyard that flows reportedly over 4500cfm (noone has real flow numbers)
Min
endwrench
PostPosted: Mon Jun 18, 2007 6:34 am    Post subject: Reply with quote
So you guys are mounting 16" fans to a 12" radiator core? Interesting.
Todd
Raceboy
PostPosted: Mon Jun 18, 2007 4:42 pm    Post subject: Reply with quote
Yep Todd, lower edge of the fan is even with the rad, upper part is higher. Maybe it's for good: drawing additional air thru 951 IC I have under badge panel
I'm going to fabricate custom aluminium rad anyway that is 16 inches high for a 2.5 16v engine.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
endwrench
PostPosted: Fri Jun 22, 2007 2:12 pm    Post subject: Reply with quote
Huh, can't think of any reason it wouldn't work and work well as you would be covering more of the width too. I just installed a 951 rad wich is 14" high so I went with a cheap $50 14" fan and it works great! First 90° day today and it ran cool as a cucumber in traffic and on the road. I actually had more trouble before with cooling at speed than in town. I think it was because the intercooler would heat soak during extended criuse. I have since installed a second blow-off to try to bleed some of this heat.
Todd
leadfoot
PostPosted: Fri Jun 22, 2007 2:29 pm    Post subject: Reply with quote
Hey Todd What's your oil temp doing??
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
endwrench
PostPosted: Fri Jun 22, 2007 2:43 pm    Post subject: Reply with quote
Oil temp? What's that?!!
Actually, I think it's getting pretty warm because I have around 5bar cold at idle but only about 1bar hot. I run 20w50wt Synthetic. An oil cooler is on the "list".
Todd
leadfoot
PostPosted: Fri Jun 22, 2007 3:02 pm    Post subject: Reply with quote
I tell you what though now I have the blower without a clutch I can feel the heat coming out of the intercooler tubing... I might seriously in the future think about one of those tube style water to air coolers and use that to replace the tubing between the blower and intercooler.
Leadfoot
