Size of seat belt bolts?
Chrenan
PostPosted: Sun Jan 28, 2007 6:33 am    Post subject: Size of seat belt bolts? Reply with quote
Does anyone know the specs for the front seat bealt bolts (all three, 2 lower, 1 upper)? PET just names them but doesn't give the size or pitch.
PostPosted: Sun Jan 28, 2007 7:58 am    Post subject: Reply with quote
this is a rough guess but I would be saying M10 w/ 1.5 pitch, could be an M12 though
3 928s,
Chrenan
PostPosted: Sun Jan 28, 2007 8:05 am    Post subject: Reply with quote
It's weird that PET doesn't disclose the info. Is there something special about the bolts? I'm assuming they are just metric 12.9?
PostPosted: Sun Jan 28, 2007 8:28 am    Post subject: Reply with quote
I would be more inclined to say 14mm x 1.25 pitch
PostPosted: Sun Jan 28, 2007 8:40 am    Post subject: Reply with quote
Diesel and myself found them to be SAE 7/16-NF20, while gohim says M11x1.25 - http://www.924board.org/viewtopic.php?t=4027
PostPosted: Sun Jan 28, 2007 10:19 am    Post subject: Reply with quote
Just was out in the shed and check with the vernier 11mm.
Cant find the screw pitch guage but 1.25 looks right.
Chrenan
PostPosted: Sun Jan 28, 2007 10:37 am    Post subject: Reply with quote
Thanks Ozzie, and everyone else.
PostPosted: Sun Jan 28, 2007 1:53 pm    Post subject: Reply with quote
I'm still real sure it's 7/16-20.
I was as sceptical as anyone to think they'd be non-metric, but I remember checking one of the belt bolts against both 11mm and 7/16" taps and found the thread pitch fell between 2 metric sizes (larger than 1.25, but smaller than the next metric tap), but right on with the 7/16-20 tap. I checked twice and started to walk back, then turned around and checked it again. -Same result of course.
Here're some VW'ers that found the same (7/16-20 seat belt bolts on their VWs) - http://www.autoforumz.com/Seat-Belt-ftopict86848.html
M11x1.25 might be close enough to use, but really they are 7/16-20.
Listen to that little voice in your head...
"it's 7/16-20 (and at least grade 5)...7/16-20..Smoothie says they're 7/16-20... ...
..and it's all because of Ralph Nader...Ralph Nader did it...did it..did it..."
PostPosted: Sun Jan 28, 2007 2:47 pm    Post subject: Reply with quote
Usuaully metric comes in even numbers 6,8,10,12 etc so unusual to have 11m.
I'd normally go with smoothie on 7/16 UNF apart from the fact that the car is Euro origin (read metric).
Chrenan
PostPosted: Mon Jan 29, 2007 1:32 am    Post subject: Reply with quote
Wow, who knew this would be such an interesting topic? I find it hard to believe any bolt on a German product would not be metric, but go figure.
PostPosted: Mon Jan 29, 2007 1:59 am    Post subject: Reply with quote
Smooth dog, you are pretty goddamn funny. Chrenan, you have a PM.
PostPosted: Tue Jan 30, 2007 5:56 pm    Post subject: Reply with quote
Just in case of any straggling non-believers... 2 pics - first with a metric 1.25mm/thread tap against a seat belt bolt (I tried to include the tap size in the pic, but all you can see of it (just barely) is ",25") -
There you see the threads meshing at the right side, then going gradually out of alignment until they're almost point-to-point at the left.
Then the same bolt held against a 7/16NF20 tap - you see the threads mesh all the way across (again I tried to include the tap size in the pic - what's barely visible of it is "16NF2" and "JAPAN" below that) -
PostPosted: Tue Jan 30, 2007 8:35 pm    Post subject: Reply with quote
Thanks - now that is sorted.
(I do have another car with different bolts, can get confusing)
Chrenan
PostPosted: Wed Jan 31, 2007 12:59 am    Post subject: Reply with quote
Thanks Smoothie. This will be a good reference when the question is ever raised again.
PostPosted: Wed Jan 31, 2007 2:58 am    Post subject: Reply with quote
Here're DOT rules on seat belts -
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/571.209.htm
Scroll down to "(f) Attachment hardware" - They say "shall have 7/16- 20 UNF-2A or 1/2-13UNC-2A attachment bolts or equivalent metric hardware". -Still a mystery why they went with the SAE size - maybe because M11 is an oddball size and 7/16NF20 shouldered bolts would be cheap an plentiful?..
