Posted: Fri Feb 02, 2007 3:43 pm Post subject: Sunroof seals |
Looking for a source for the inner sunroof seal,
goes on the body not the sunroof.
Aides in holding roof liner
I dont need so much the one that goes in the sunroof.. as much
the one that goes around the frame on the top of the car
hold part of the roof liner up as well as seal the sun-roof
its part of the sealing sys. Mine leaks I need it fixed
before I install stuff back there. it mostly leaks on the
rear passenger corner.. runs down and dribbles off the
end of the long cushioned side piece of the roof liner. _________________ 1979 porsche 924 Na
Tiny
Posted: Sat Feb 03, 2007 12:12 am Post subject: |
I have the same problem....i am still trying to get to the bottom of it.
here's my original thread:
http://www.924board.org/viewtopic.php?t=20614
smoothie said that osmosis can pull water into the car past the sunroof seal which attaches to the body....
So i replaced this seal properly....using silicon sealer underneath....a nice job...tighter fitting sunroof.... and i thought that was the end of it.
The other day.. after it rained... i'm backing out of the car park space...and as i look over my shoulder... i see water literally spill.....not just drip....down from the rear sunroof latch area onto the rear seat!
grrr. i can't figure it out.....when i test manually with the sunroof off....the water channels out perfectly...
however with the sunroof on.....it just keeps on soaking the rear seat.
Tiny _________________ *****1981 - 924 - Auto - London, UK****** |
Posted: Sat Feb 03, 2007 2:16 pm Post subject: |
Im not gonna put up with it leaking.. 20 bucks
and ill have a new body seal _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
