how to remove...
deathxninja
PostPosted: Sun Jan 14, 2007 12:32 pm    Post subject: how to remove... Reply with quote
Those damn fuel things.....
81 924 turbo
PostPosted: Sun Jan 14, 2007 12:57 pm    Post subject: Reply with quote
14mm wrench, and 12 mm wrench,
undo the fuel line off the injector or at least loosen, then unscrew the injector.
3 928s,
PostPosted: Sun Jan 14, 2007 3:31 pm    Post subject: Reply with quote
On an NA they just pull up but on a turbo they have to unscrew from the head.
Loosen or remove the fuel line as said earlier.
PostPosted: Mon Jan 15, 2007 3:34 am    Post subject: Reply with quote
Those should be real easy with all the access room. Use both wrenches at the same time - Put the lower (12mm) wrench on, then the upper 14mm oriented 30-or-so degrees clockwise of the lower wrench, then take them both in one hand and squeeze together. -Then loosen and unscrew the injector with the 12mm. The holder may come out with it - that's fine, otherwise obviously unscrew the holder seperately. Before reinstalling, (if you're going to), clean up all the threads the best you can. +You'll probably find the inner space between injector and holder needs cleaning. The larger holder threads can be done with either a toothbrush or small wire brush and vacuum. Vacuum while brushing the internal head threads to keep grit out of the engine. I put a bit of plumbers teflon lube ("pipe dope") on those large external holder threads to ease reinstallation and lessen the possibility of the threads grabbing and crossthreading or cracking. The torque spec for the holders ("insulating connector piece to cylinder head") is 22-25 Nm or 16-18 ftlb.
Injector to holder torque is 6-7 Nm or 4.5-5.0 ftlb.
deathxninja
PostPosted: Mon Jan 15, 2007 9:45 am    Post subject: Reply with quote
Thanks. Its nice having knowledgable people to get advice from. I am lost when it comes to these german rides, but I do love them.
Any advice for rooming the head?
81 924 turbo
PostPosted: Mon Jan 15, 2007 12:51 pm    Post subject: Reply with quote
yup, it helps to lift it up out of the bay after everything is removed
3 928s,
Benino
PostPosted: Tue Jan 16, 2007 4:08 am    Post subject: Reply with quote
You should loosen the head bolts in a kind or random pattern instead of sequential from one end to the other. This decreases the possibility of warping.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
drewnashty
PostPosted: Sun Jan 21, 2007 10:17 am    Post subject: Reply with quote
Must the entire engine come out of the bay in order to take the head off? I am running into an issue with removing the head where the back side of the hide hits the firewall when sliding the head out and there is still another inch or two of the head studs inside of the head. There's no room or place to try jacking the motor up on oneside a bit just to get the head to angle more towards vertical. Tried jacking the engine up as far as possible without hitting the bellhousing on the firewall still not enough room.
PostPosted: Sun Jan 21, 2007 10:42 am    Post subject: Reply with quote
Rumor has it that it can be done on a 931
BUT
rumor also has it that it's easier to pull the motor.
PostPosted: Sun Jan 21, 2007 10:43 am    Post subject: Reply with quote
normally the head doesnt have head studs, it normally is just bolts,
however if there are studs, is there an allen key slot in the end to be able to remove the studs from the block?
3 928s,
PostPosted: Sun Jan 21, 2007 11:22 am    Post subject: Reply with quote
Is this how Raceware studs are set up?
PostPosted: Sun Jan 21, 2007 11:57 am    Post subject: Reply with quote
Unless they changed the design since I got mine, no there's no hex socket in the ends of Raceware head studs. I noticed the possible future problem while installing mine and cut a slot in the top of the studs so a flat-blade screwdriver could be used to remove them with the engine in the car. You might be able to to use 2 nuts tightened against each other at the end of the stud and a wrench to back them out - if you can find room to do it.
Min
PostPosted: Sun Jan 21, 2007 12:20 pm    Post subject: Reply with quote
I just got a set, they havn't changed their design, I personally didn't cut the slot becuase they are only supposed to be finger tight in the block according to the installation instructions, and for fear of destroying the metal temper.
Min
PostPosted: Sun Jan 21, 2007 1:18 pm    Post subject: Reply with quote
This may work:
Remove nuts and washers, lift head as high as you can, and put a small piece of wood between the head and the block to hold the head.
Then use your fingers or a pair of pliers to twist the studs out.
PostPosted: Sun Jan 21, 2007 1:56 pm    Post subject: Reply with quote
Paul wrote:
This may work:
channel lock pliers I would imagine to be the best, and use vice grips or a very small pipewrench as the last resort.
3 928s,
