Benino
Posted: Tue Feb 06, 2007 6:23 am Post subject: air fuel ratio problem |
I installed an air fuel ratio gauge in my '80 931. The computer seems to be responding normally to O2 sensor output when I start up the car. The air fuel ratio goes from lean to rich and bounces back and forth. Driving around town this works normally, but when I get on the freeway, after a few miles just cruising (off boost, although this problems seems independent of boost) the gauge will slowly stop bouncing back and forth and start showing almost completely maxed out on the rich side. It stays pretty steady there whether I floor it or let off the gas etc. If I flick the ignition off and back on it instantly starts responding to o2 sensor output like normal again and will work normally for a few miles. Any ideas? I'm thinking maybe my computer (o2/frequency valve control unit) is going bad. Has anyone had this problem before? _________________ 1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA |
Posted: Tue Feb 06, 2007 7:12 am Post subject: |
probably your computer has a bug or some sort of missunderstanding with the O2 sensor. _________________ Supercharger and EFI kits
flosho
Posted: Tue Feb 06, 2007 7:30 am Post subject: |
The bouncing around from lean to rich will always be there especially when driving around town.
If you are on the highway and put it down, hold it for a few seconds and then let off, does it bounce back to lean for a second on decel?
I can't remember what mine looks like but I think your a/f gauge is doing the same thing mine does after it warms up.
The main problem is that its a narrow band gauge. I would suggest going to a wide band. The difference is that (IIRC) the narrow band gauge works on voltage between .5 and 1 volt. The wide band sensor/gauges read from .5 to 5 volts.. a much more precise measurement.
Now, you didn't waste your money on that narrow band gauge, all you have to do is search ebay for the LC-1 wideband gauge by Innovative.. It will be about $190-$200 and you can actually convert your narrow band gauge to wideband. The innovative LC-1 kit comes with just the o2 sensor, bung, software, and the wiring.. no actual gauge. You can connect it to the serial port on a laptop and actually log the a/f's.
The other way you can go is AEM UEGO, which is an all in one kit for about $250. But its essentially stand alone in that it wont work with megasquirt or other EMU other than the AEM ones. But this kit does include everything. _________________ [This Space For Rent] |
Benino
Posted: Tue Feb 06, 2007 8:08 am Post subject: |
| flosho wrote: |
Now, you didn't waste your money on that narrow band gauge, all you have to do is search ebay for the LC-1 wideband gauge by Innovative.. It will be about $190-$200 and you can actually convert your narrow band gauge to wideband. The innovative LC-1 kit comes with just the o2 sensor, bung, software, and the wiring.. no actual gauge. You can connect it to the serial port on a laptop and actually log the a/f's....
I actually recently ordered the LC-1 kit. I have it sitting at home. I have welded in the bung for the wideband o2 sensor. I just haven't gotten around to installing it and running the wiring. My other cars are not running at the moment and with work and everything else I haven't had a free minute to work on my 931.
From my understanding when I'm not under boost the car shouldn't be running so rich that it is maxing out the narrow band gauge. I could be wrong. I do have a catalytic converter on this car. I just worry that I am running too rich and will clog up the cat. I am glad for the fact that if anything, I'm running rich instead of lean. I'd rather screw up the cat than blow a motor.  _________________ 1980 Porsche 924 N/A USA
Posted: Tue Feb 06, 2007 9:12 am Post subject: |
Just make sure you are not diluting your oil with all that fuel... _________________ White 87 924S "Ghost"
Posted: Tue Feb 06, 2007 4:33 pm Post subject: |
Just to allay your fears some, I've noticed the same thing - the gauge reading high for seemingly extended periods. -And I don't have a fuel-in-the-oil problem. You should see a steady reading during warm-up and approximately the first 5 min., then at idle and steady cruise it should bounce up-down in a regular pattern indicating closed-loop mode. Then while cruising, if you step on the gas (doesn't have to be full throttle), it comes out of closed-loop and gives a higher, steady reading. Then when you go back to a steady cruise at part-throttle it should go back to closed-loop. Mine sometimes doesn't go back to closed-loop as soon as I'd think it should, but eventually it does. Anyway, I don't think you should worry yourself too much about it going so rich that its' contaminating the fuel. At least in my case it isn't. _________________ "..it's made in Germany. You know the Germans always make good stuff."
