bass gt
Posted: Fri Jan 05, 2007 9:30 am Post subject: Clutch Slave Cylinder Q |
Guy's,
It looks like i need a new clutch slave cylinder for the 931. Are they specific to these cars, or are they a shared component with the 944/951 models. I was thinking they might be the same, as the bellhousing must be similar, but am waiting to be proven wrong!!
Thanks,
Steve |
Posted: Fri Jan 05, 2007 10:23 am Post subject: |
They're the same through 931-924S-944-944S2-951.
The 931.116.237.00 number was superceeded to 944.116.237.00, so either one of those numbers'll do ya.
It's in too bad of a condition for a rebuild? (seal kits can be had here for $18US, complete replacement slave cyls for $114US) _________________ "..it's made in Germany. You know the Germans always make good stuff."
bass gt
Posted: Fri Jan 05, 2007 8:59 pm Post subject: |
Smoothie,
Thanks or that. The bore is a bit scored as the seal has perished. The fluid is black with the disintegrating rubber!! I would rather just fit a new one and forget about it.
Steve |
Posted: Sat Jan 06, 2007 5:20 am Post subject: |
Better do the master at the same time. . . _________________ Toofah King Bad
bulldog fred
Joined: 03 Mar 2006 Posts: 13 Location: uk - portsmouth
Posted: Sat Jan 06, 2007 5:38 am Post subject: |
hi - steve
i have plenty of the clutches bits and pieces i do believe i would have what you are looking for drop me aline steve 01243 268105 or i shall give you a ring tomorrow
regards - fred _________________ bulldog fred
1980 931 s1 silver
1982 931 s2 red - moded intercooler, water injection, avo sports suspension 944 turbo sway bars,green stuff brakes (brilliant) |
bass gt
Posted: Sat Jan 06, 2007 9:05 am Post subject: |
Rasta,
No need to. I am fitting a Tilton 3 way floor mounted pedal box into her with bias brakes, and the clutch master is included.
Steve |
