billmay34
Posted: Wed Jan 10, 2007 2:27 am Post subject: Wheel Bearing howl or just not enough grease? |
New Years greetings to all!
The Purple Martini has a wheel howl! We are submitting our information here in hopes of sage advise.
Symptoms: Wheel noise when rolling that quiets down upon steering changes.
Response so far: purchase new bearings and attempt removal and install of new bearings.
Problem: now that the wheel and brakes and transaxle are disassembled we are having a heck of a time getting the splined axle out of the original mounting. All of this makes us consider if perhaps the original howling was the result of a poorly adjusted/tightened crown nut on the axle our insufficient lubrication in the first place. The general area is coated with a fine dust of a rust coloration that might indicate that lubrication and proper tightening of the crown nut was the main problem.
Is there an easy way to remove the splined wheel post? As long as we are in there we will renew the bearings and then reassemble with appropriate amounts of lubrication.
If anyone here has any words of wisdom (or pity) we hope you will share your advise and expertise.
Pictures at: http://s144.photobucket.com/albums/r177/billmay34/wheel/ _________________ Bill May
Seattle, WA
1991 MB 300E - 202,000 Miles
1977 Porsche 924 Martini - 85,000 Miles, Purple. |
Posted: Wed Jan 10, 2007 2:37 am Post subject: |
there is just abit of corrosion in there, take a 2x4 and hold over the end of the shaft so as not to damage the threads and get a 20lb sledge hammer and give it a couple of whacks it will come out. _________________ 3 928s, |
Mike924
Posted: Wed Jan 10, 2007 6:06 pm Post subject: |
I see you're wearing the correct safety footwear for that sort of job.  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Wed Jan 10, 2007 6:13 pm Post subject: |
Better than mine.
 _________________ Porsche 924 1984 (UK import) NA
Mike924
Posted: Wed Jan 10, 2007 6:15 pm Post subject: |
LOL _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
rusto
Joined: 06 Jan 2007 Posts: 11 Location: Portsmouth, UK
Posted: Wed Jan 10, 2007 6:37 pm Post subject: |
| Use a big 2 legged puller or if you're going to hit it, take the trailing arm out and support it from behind or you'll be shocking the suspension. |
billmay34
Posted: Wed Jan 10, 2007 7:31 pm Post subject: Damn thing stuck solid! |
I beat the H*** out of the spline and no movement. Then I checked for in-out, left right, up down movement and decided to reassemble with a boat load of grease on the CV joint and spline.
the noise is diminished yet not gone. i will post a UTUBE link for your listening and diagnostic pleasure. i hope someone will have some advise for us.
the BFH did not budge the spindle! _________________ Bill May
Seattle, WA
Posted: Wed Jan 10, 2007 7:45 pm Post subject: |
Well then I'd say its either cooked or rusted in and it should not be back on the road till fixed.
The short shaft comes out but needs more force.
This is what is supposed to come off
Posted: Wed Jan 10, 2007 11:42 pm Post subject: |
Yea with those short shafts
you should of been able to knock them out.
I replaced both sides, inner and outer a while back
Sage advice hmmm never heard that before.
http://www.geocities.com/Heartland/Farm/7478/sage-adv.htm _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Thu Jan 11, 2007 12:13 am Post subject: |
I've never had a hard time getting them out - just a little work with a hammer, but then mine might be a little worn...  _________________ Vaughan Scott
spiraloutse4n
Posted: Thu Jan 11, 2007 5:35 am Post subject: clip? |
| ozzie, in the picture you posted it looks like theres a circlip there.. where does that go? could it be holding my spline in place? |
Posted: Thu Jan 11, 2007 5:41 am Post subject: |
...if they howl they might do what mine did & thats come apart
then the balls would get stuck and a very loud 'Bang' noise
could be heard the first time that started happenin scared
me ...thought
I was getting shot at lol. _________________ 1979 porsche 924 Na
Posted: Thu Jan 11, 2007 5:47 am Post subject: Re: clip? |
| spiraloutse4n wrote: | | ozzie, in the picture you posted it looks like theres a circlip there.. where does that go? could it be holding my spline in place? |
Seems unlikely. . .here's a pic:
-nick
Posted: Thu Jan 11, 2007 5:57 am Post subject: |
The circlip just holds the rear bearing in from what I remember.
I've used the piece of wood between the shaft and a hammer with success. You just need a little more oomph Or a pick up a big gear puller from your local auto parts tool exchange program. Around me, both Autozone and Advanced Auto have them. _________________ 1980 931S
1991 964 C4 Cabriolet |
Posted: Thu Jan 11, 2007 6:00 am Post subject: |
Hmm, mine both slid out like they had bearing grease all over them, must be the low mileage on the car. _________________ Toofah King Bad
