Desktop Dyno
DD69
PostPosted: Sun Jul 01, 2007 8:07 am    Post subject: Desktop Dyno Reply with quote
I've tried to simulate the 2.0 NA engine in Desktop Dyno but I can't get the figures right.
Does anyone have file with the flow in the head as well as the file for the cam?
flosho
PostPosted: Sun Jul 01, 2007 8:39 am    Post subject: Reply with quote
Go to www.integralcams.com and use the stock 924 file cam.
[This Space For Rent]
PostPosted: Sun Jul 01, 2007 10:17 am    Post subject: Reply with quote
For the stock head flow go to Applebit's site at http://come.to/924.org then click Engine and the Port & Polishing Head: Results. Jon has the stock flows and the results of a p&p.
endwrench
PostPosted: Sun Jul 01, 2007 11:30 am    Post subject: Reply with quote
With the correct port flow numbers it is amazingly close to real world dyno numbers.
Todd
flosho
PostPosted: Sun Jul 01, 2007 12:42 pm    Post subject: Reply with quote
Where can I download a good desktop dyno program??
DD69
PostPosted: Tue Jul 03, 2007 3:05 am    Post subject: Reply with quote
I'm still about 20Hp too low even with the flow from his head.
I'm not sure if I got the camshaft right, the current values are:
cam specs@: 0.050
lifter: hyd.
lift: 12mm
lobe centre 110.3
valve overlap: 8
int. duration: 228
ext. duration: 229
IVO: 6
IVC: 42
EVO: 47
EVC: 2
Timing: -7
The engine is euro and the peak Hp is at 5500rpm and peak tork is at 4000rpm.
PostPosted: Tue Jul 03, 2007 3:22 am    Post subject: Reply with quote
the liftrs are solid,
and Euros ran at 10 deg BTDC
3 928s,
DD69
PostPosted: Tue Jul 03, 2007 3:36 am    Post subject: Reply with quote
112Hp at 5500rpm and
123 ft-lbs at 4000rpm.
Getting closer
PostPosted: Tue Jul 03, 2007 5:10 am    Post subject: Reply with quote
now the timing it is asking for is that max or at idle, as the spec I gave you was for timing at idle, I am not sure what max timing is on the euros though.
3 928s,
PostPosted: Tue Jul 03, 2007 5:32 pm    Post subject: Reply with quote
According to graphs in Haynes manual:
Max. centrifugal advance 34 - 38 degrees above 3400 rpm
Vacuum: additional 8 - 12 degrees max, above (below?) 21 kPa manifold depression
DD69
PostPosted: Sat Jul 07, 2007 3:35 am    Post subject: Reply with quote
I misunderstood the timing I think, it's the timing of the cam so it probably should be 0.
I still don't get more than about 110Hp though. Since I got the flow values from the head and the cam profile there must be something else wrong.
PostPosted: Sat Jul 07, 2007 10:42 am    Post subject: Reply with quote
What compression ratio are you using?
DD69
PostPosted: Sat Jul 07, 2007 10:17 pm    Post subject: Reply with quote
These are the current values I use:
Block: Porsche 2.0
Bore: 86.5
Stroke: 84.4
Intake Valve: 40mm
Exhaust Valve: 33mm
Compression: 9.3
Induction flow: 500.0 cfm @ 1.5inHg
Fuel: Gasoline
Manifold Type: Tuned-Port Injection
Exhaust: H.P Manifolds And Mufflers
Lifter: Solid
Cam Specs@: 0.050-lift
Int Lift: 12mm
Exh Lift: 12mm
Timing: 0.0
IVO: 6.0
IVC: 42.0
EVO: 47.0
EVC: 2.0
This gives me 114Hp @ 5000rpm and 133ft-lbs @ 3750rpm.
PostPosted: Sun Jul 08, 2007 1:29 am    Post subject: Reply with quote
well try @ 5800 RPM and see whats the power there. The 924 NA peaks a 125 HP at 5800 RPM.
DD69
PostPosted: Sun Jul 08, 2007 1:53 am    Post subject: Reply with quote
The peak is at 5000rpm, at 4500 I've got 109hp and at 5500 it's 113hp and 6000 is 107hp.
