Why do door check straps break?
79porsche
PostPosted: Wed Jan 03, 2007 7:30 am    Post subject: Why do door check straps break? Reply with quote
Working on my 924 going from one issue to the next...and making progress. One of the next is two broken door check straps. Is this a common issue...and if so....why would they break. I see no reason why these check straps should be broken.
I'm definately going to need to replace these asap.
PostPosted: Wed Jan 03, 2007 8:28 am    Post subject: Reply with quote
Door stop straps are a secondary failure part - something else has to go wrong first, then the straps fail. It happens like this...something breaks - waterpump, fuel pump, whatever, leaving the car and occupants stranded on the side of the road 10 or more miles from home. Then both doors fly open with excessive velocity and the straps break as the PPOO (previous pissed-off owner) and PPOOPSO (previous pissed-off owners' passenger seat occupant) exit the car, each in a huff.
Mine are still good (my PPOO obviously preferred punching out the dash and elbowing the center armrest), but door strap failure isn't too unusual.
kojab
PostPosted: Wed Jan 03, 2007 9:52 am    Post subject: Reply with quote
My drivers side (RH) has broken too. I did notice that the passengers door was getting very hard to close and lubricated the door check strap with grease. What a difference a bit of lube makes. Also noticed how badly worn the surface of the check strap was. Maybe they break because the surface hardening is removed from lack of lubrication which then allows them to possibly stretch and then break.
Where can I buy one of these straps?
Richard
JB 924
PostPosted: Wed Jan 03, 2007 1:47 pm    Post subject: Reply with quote
The one on my other car is broken on the driver's side, too. It's because they don't get lubricated, and once the mechanism fails, it can actually rip the door like it had on my 924, and also the Bimmer.
79porsche
PostPosted: Thu Jan 04, 2007 5:48 am    Post subject: Reply with quote
Are the fasteners which hold the strap to the pillar and door a 5 mm (12 point) fastener? Whatever they are...I don't have one.
PostPosted: Thu Jan 04, 2007 6:14 am    Post subject: Reply with quote
Its metal fatigue from the low grade pot metal stretching every day for 20+ years.
79porsche
PostPosted: Thu Jan 04, 2007 7:27 am    Post subject: Reply with quote
The bolts that hold on the check strap are triple square (12-point) fasteners....but not sure what size.
Llamaguy
PostPosted: Thu Jan 04, 2007 8:39 pm    Post subject: Reply with quote
It's that cheap communist steel buckling under our capitalist might
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
PostPosted: Fri Jan 05, 2007 3:26 am    Post subject: Reply with quote
On my car all two to get broken and i removed the complete mechanic-stuff from the doors too.I can tell you that heavy stuff makes the diffrence...
(German word for check-strap is Tuerfangband)
Driving without makes live easier.....
