High tension (igntion) leads question
falconboy
PostPosted: Thu Dec 28, 2006 11:12 pm    Post subject: High tension (igntion) leads question Reply with quote
Forgive my ignorance but besides getting the right length is it necessary to get the ignition lead kit specified or can I just get some the right length with the same plugs? As far as I can tell the plugs are all pretty much the same and the only difference is the length, is this right because there seems to be a large selection? The reason I ask is one of mine broke and I'd get the specified ones if I could but it's going to take over a week to order them in.
PostPosted: Fri Dec 29, 2006 12:19 am    Post subject: Reply with quote
Yes, for the non-turbo any good ignition wire should do. For the turbo, I prefer to have the factory style connector, though it's still less critical than as in a 924S or 944.
Jaf
PostPosted: Sun Dec 31, 2006 6:51 am    Post subject: Reply with quote
The only thing I'd watch out for is that the leads are ones with the heat shields on them. Otherwise they'll not last long.
Jaf
1978 924na
