for those newbies out there. FYI
germ924
PostPosted: Fri Dec 29, 2006 4:48 pm    Post subject: for those newbies out there. FYI Reply with quote
WHEELS -------4 on 108 mm (4-1/4")
Alfa Romeo (exc. Alfetta)
Ford - Fairmont '78-'86
- Mustang 4-bolt patterns '74-'93
- T-Bird '80-'88
- Pinto '71-'80
- Fiesta '78-'85
- Escort all (RWD and FWD)
- Cortina all
- Taurus, Tempo, EXP to '89
- German-built Capri I, II, III '69-'78?
- Mercury - Capri '71-'88
- Cougar '79-'88
- Merkur, Topaz, Lynx '80-'89
- Zephyr '78-'86
Plymouth Cricket
Porsche - 924 '77-'84
Sunbeam - Tiger, Alpine '65-'70
PostPosted: Sat Dec 30, 2006 2:34 am    Post subject: Reply with quote
That is quite an informative thread title.
PostPosted: Sat Dec 30, 2006 7:05 am    Post subject: Reply with quote
Anyone have the stud pattern of a 914?
PostPosted: Sun Dec 31, 2006 2:02 am    Post subject: Reply with quote
Wrong forum, Ozzie!
alexvex
PostPosted: Sun Dec 31, 2006 5:09 am    Post subject: Reply with quote
Not all exactly right. Escorts pre 1991 are 4x108, but 91 and after are 4x100. All focus are 4x108 though.
--Alex--
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951
PostPosted: Sun Dec 31, 2006 7:40 am    Post subject: Reply with quote
It is relevent cos somone asked about fitting 914 discs to the rear of a 924.
Seem to think the disk will fit over the drum and bolt on to the drum using the wheel bolts.
As well as using the same 924 wheels.
I said the stud pattern is different IIRC.
leadfoot
PostPosted: Sun Dec 31, 2006 8:48 am    Post subject: Reply with quote
Early Mazda's 626 ('79)have the same pattern, I put my old 6 X 16"s on the girlfriends car and they fit...just...
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
tomcooper
PostPosted: Sun Dec 31, 2006 9:32 am    Post subject: Reply with quote
Ozzie,
You recall correctly. The 914 and the 924 have different four bolt spacing. Don't know what the specs. are for the 914, but you could probably find out at ClubNarp.com.
I also don't see the rear rotors fitting over the exisiting 924 hubs even if you redrilled the bolt pattern. I suppose that it could be done with enough machine work, but with the 914 folks going to bigger brakes, why not do a five bolt conversion?
Tom
Casper and Big Red, both 1980 NA
Black Bart, 1990 944 S2 Cab
leadfoot
PostPosted: Sun Dec 31, 2006 3:27 pm    Post subject: Reply with quote
Or you can use 928 rotors as on the S model... not 924S but S for sports... I have seen an S car go with this setup...
Leadfoot
PostPosted: Sun Dec 31, 2006 7:27 pm    Post subject: Reply with quote
I'm happy with the 4 bolt setup.
I was originally going to 5 lug.
Andrew NZ
PostPosted: Mon Jan 01, 2007 10:37 am    Post subject: Reply with quote
Leadfoot
Early Mazdas were 4x110, so although they will sometimes fit (depending on the wheel) they aren't ideal.
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
driver1
PostPosted: Tue Jan 02, 2007 6:01 am    Post subject: Reply with quote
I'm not sure about the Lfa Romeo, I have a '86 Spider sitting next to a '78 924 in the garage and thought about switching wheels one day, the bolt pattern is the same but they won't clear the blake caliper on the Alfa.
