Coolant overflow tank - changes?
B
PostPosted: Wed Dec 20, 2006 9:15 am    Post subject: Coolant overflow tank - changes? Reply with quote
I had wanted to move/change the overflow tank on my '79 NA to make it a little easier to work on the motor. I was wondering if anyone else has moved or changed their set up with this and what you used for this? I thought I had seen someone use some type of catch can - but I could not find one that had the radiator cap like ours. Any ideas would be greatly appreciated.B
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Wed Dec 20, 2006 9:28 am    Post subject: Reply with quote
alot of people relocate the ign control module, and use the 944 over flow tank.
3 928s,
B
PostPosted: Thu Dec 21, 2006 7:35 am    Post subject: Reply with quote
thanks Lizard
I am not familiar with the 944 set up, it sounds like it is placed in front of the driver's side wheel.? Do you know how easily it fits or if there are any adaptations that need done besides hoses? I will try to find some pictures of the 944 set up.
thanks very much
B
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Thu Dec 21, 2006 8:16 am    Post subject: Reply with quote
The 944 tank mounts higher-up on the front of the wheel well and attaches via the fender bolts as far as I know.
I didn't think you'd need to relocate the ignition trigger/module - for clearance anyway.. -Or do some relocate it just to eliminate possible spills on it while refilling the coolant?
B
PostPosted: Fri Dec 22, 2006 12:44 pm    Post subject: Reply with quote
Thanks Smoothie
I will probably move the ignition just to be safe - I'm working on locating a reasonably priced tank - performance's last price (unless I looked at it wrong) was $89. Not exactly the price that's goig to get me to run out and buy one right away.
Thanks again - as always - the information that all of you provide on this forum is extremely helpful and appreciated.
B
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Fri Dec 22, 2006 12:52 pm    Post subject: Reply with quote
it is needed to be moved for clearance I believe,
the unit is water proof so no need to worry about spilling water on it.
3 928s,
PostPosted: Fri Dec 22, 2006 1:19 pm    Post subject: Reply with quote
I thought about it too
though the job doesnt make it
worth it cost wise youll need
hose and the tank for starters
Slam
PostPosted: Sat Dec 23, 2006 6:43 pm    Post subject: Reply with quote
Another issue with using the 944 tank is the placement of the air box on the 924. I've got a couple of 944 tanks here and wanted to put one in my wife's 924. A quick check showed the 924 air box would have to be dealt with. Anyone got any pointers on that? And I don't really want to use a K&N filter.
