Posted: Thu Dec 21, 2006 2:56 am Post subject: 8 spoke 4 lug numbers please. |
Anyone that knows exactly the specs of the 8 spoke rims ?
I'm selling a set of 5 to a guy and he is asking me the "ET"
i know they are 4x108 , 14" diameter and 6" wide but i dont know the ET. _________________ Supercharger and EFI kits
Posted: Thu Dec 21, 2006 3:20 am Post subject: |
All the info the buyer should need is here (from the Tech Section).
Look under backspacing and offset in the spec chart. _________________ Toofah King Bad
Posted: Sat Dec 23, 2006 3:16 am Post subject: |
hello,
ET stands for Einpress-Tiefe.
not sure right now what it means.
Nobbi  |
Posted: Sat Dec 23, 2006 3:26 am Post subject: |
According to Google translate, "Einpress-Tiefe" means "offset" and "Einpress Tiefe" (without the dash) means "press depth in". _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Sat Dec 23, 2006 3:42 am Post subject: |
Hey,
i checked on the net. ET ( einpresstiefe) means the distance between the center of the wheel to the point where it contacts the car.
If you change from ET 30 to ET 25 the track-width will be greater (5 mm).
Check this side www.komplettrad.biz/einpresstiefe.html
The ET size must be on the rim somewhere!(At least when it is a german one.)
Nobbi  |
Posted: Sat Dec 23, 2006 7:39 am Post subject: |
Hey Nobbi thanks for that link ! _________________ Supercharger and EFI kits
Posted: Sat Dec 23, 2006 2:30 pm Post subject: |
ET same as offset.
Looks to me like decreasing offset would decrease track by a factor of two. . . _________________ Toofah King Bad
