Front Seat Removal
isuras2
PostPosted: Thu Dec 21, 2006 11:54 pm    Post subject: Front Seat Removal Reply with quote
I have been trying to remove the front seats. I know I need to just remove the bolts, but my socket doesn't work. I did a search on this, and a socket will work. I guess I'll keep trying. I can move the seats forward/back so that isn't an issue with me.
Thanks,
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
Chrenan
PostPosted: Fri Dec 22, 2006 1:10 am    Post subject: Reply with quote
Is is tricky to get a socket on the 4 bolts that hold a seat down as the head of the bolts is deep in the seat rail. Try to find a socket with narrow edges that fits between the rails.
PostPosted: Fri Dec 22, 2006 3:57 am    Post subject: Reply with quote
I have to use my 1/4" drive sockets to get at them.
PostPosted: Fri Dec 22, 2006 7:14 am    Post subject: Reply with quote
When you do get them off replace with allen head bolts.
isuras2
PostPosted: Fri Dec 22, 2006 7:31 am    Post subject: Reply with quote
Allen heads will be easier access and new! Now if I can find a socket that is thin enough and will fit...
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Fri Dec 22, 2006 10:43 am    Post subject: Reply with quote
A Craftsman 10 mm socket 1/4 inch drive with a 3 inch extension and a flex head stubby rachet always works for me
das push
PostPosted: Fri Dec 22, 2006 1:05 pm    Post subject: Reply with quote
When I did mine I used a a socket with the nut driver(screwdriver) attachment. Allowed for a little more wiggle room.
1982 924 NA 85K owned since 1992
82 nicknamed das push"the push"by my kids.
lots of electrical problems 1st yr of owner ship!
isuras2
PostPosted: Fri Dec 22, 2006 1:43 pm    Post subject: Reply with quote
How far does the chair go back? I don't think my chair goes back far enough as the bottom of it is just above the bolt so I can't get even a socket to fit...eventhough I have the right size and it fits!
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Fri Dec 22, 2006 1:48 pm    Post subject: Reply with quote
Huh? No gangly wrench?
PostPosted: Fri Dec 22, 2006 3:22 pm    Post subject: Reply with quote
It should go far enough back to expose the bolts and provide room for a 1/4" drive socket wrench. Make sure there's nothing below/behind the seat, sit in it, move it forward, then slam it backwards. If no luck, call over the nearest 250 lb.+ neighbor to try it.
Vince Ponz
PostPosted: Sat Dec 23, 2006 5:45 am    Post subject: Reply with quote
You probably have rust under the rails. Push them as far back or forward and tap them with a hammer on the back of the rails. WD40 apply as needed.
If that does not work get a large sledge hammer and whack the rail.
NOOOOOOOOOOOOOOO..............just kidding about the sledge.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
isuras2
PostPosted: Sat Dec 23, 2006 9:45 am    Post subject: Reply with quote
Good news and bad news. Good is I got the drivers' seat out completely...bad is I got one front bolt of passenger seat out and the other just turns and turns and turns and gets no looser. I haven't even attacked the back 2 bolts on that chair. I'll try those tonight.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Sat Dec 23, 2006 2:23 pm    Post subject: Reply with quote
I found the nut which is part of the body had broken away on mine. I had to lever up the rail with a wrecking bar/ large screwdiver at the same time as undoing the bolt.
The body and nut had all cracked and broken away so I ended up welding in a 1/4 steel plate then drilling and tapping into that as a repair.
isuras2
PostPosted: Sat Dec 23, 2006 2:50 pm    Post subject: Reply with quote
The nut broke through the body and left a gaping hole...so I will have to do the same.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
