Chrenan
Posted: Fri Dec 15, 2006 9:17 am Post subject: Fuel Line Thread Sizes? |
Hi Guys,
I'm thinking of replacing some aging fuel lines with AN versions. Does anyone know the metric thread size and pitch of the following fittings - the threads on the end of the injector and the threads on the bolt that holds the injector lines to the fuel distributor?
 _________________ 1987 951 - M193 Version for Japan |
Posted: Fri Dec 15, 2006 12:55 pm Post subject: |
The item 16s'd be M8x1.0.
Don't happen to know the 26es, but I can say definitely they're something different. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Fri Dec 15, 2006 2:05 pm Post subject: |
Oh wait...I have a guess based on memory and the adapters in my CIS pressure tester kit.. The line-to-injector thread size (the 26es) should be M12x1.5. I'd give it a 95% sureness that that's correct. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Chrenan
Posted: Sat Dec 16, 2006 1:05 am Post subject: |
Wow, thanks Smoothie. Now to see if I can find some fittings... _________________ 1987 951 - M193 Version for Japan |
Chrenan
Posted: Sat Dec 16, 2006 2:29 am Post subject: |
Hmmm, it seems M12x1.5 won't be too hard, but M8x1.0 seems to be hard to find, anyone have a good source for automotive plumbing? _________________ 1987 951 - M193 Version for Japan |
koolkarateguy
Joined: 16 Dec 2005 Posts: 108 Location: Nova Scotia ,Canada
Posted: Sat Dec 16, 2006 1:53 pm Post subject: |
I broke a fitting on one of my fuel injector lines. So far I've had no luck finding new ones (reasonably priced anyway) I had to make a new one out of stainless steel brake line. Not pretty but it works.  _________________ 1979 N/A 924 |
