Fuel cutting at 0.95 bar?
u63af
PostPosted: Sun Nov 19, 2006 8:19 am    Post subject: Fuel cutting at 0.95 bar? Reply with quote
Hi,
I raised the boost on my car the other day and it seems to be stuttering at 0.95 bar. It feels like its fuel cutting. Can anyone think of a reason for this as I thought the boost cut off was at 22 psi? Car is running a standard turbo with a front mount.
Cheers
Sandy
PostPosted: Sun Nov 19, 2006 10:05 am    Post subject: Reply with quote
Might you be hitting the rev-limit?
Of course the problem could be a faulty overboost cutoff switch. As long as your wastegate is working and boost is being reliably limited, there should be no harm in grounding the wire to the overboost switch as a quick test.
PostPosted: Mon Nov 20, 2006 2:09 am    Post subject: Reply with quote
Another possibility - A vacuum (/boost actually) leak that only opens up at the higher pressure level. My car did this (hesitation, stuttering while under boost, but not quite as severe as the fuel cutoff) when the bracket that holds the lower charge tube to the block came loose. This allowed the charge tube to seperate from the turbo when a certain level of boost was attained because there's only an o-ring joint between the turbo and the lower charge tube. It took a long time to diagnose because the joint would slip back together as boost decreased - so everything seemed fine when looking at it with the engine shut off.
u63af
PostPosted: Mon Nov 20, 2006 3:01 am    Post subject: Reply with quote
I dont think it is a vacuum leak as all my pipes are silicone hose now. Will try earthing the boost cut off switch.
Cheers
u63af
PostPosted: Mon Nov 20, 2006 3:02 am    Post subject: Reply with quote
Dont think its rev limiter as only taking itup to about 5000 rpm
