Transmission Grinding
isuras2
PostPosted: Fri Nov 10, 2006 4:02 pm    Post subject: Transmission Grinding Reply with quote
My tranny has been grinding for a while and has gotten worse. I know it isn't the wheel bearings or cv's. I think it could be the tapered roller bearing (p/n: 999 059 027 00) on the joint flanges. What are the chances that these bearings are bad vs the ring gear and pinion shaft bein bad? I am thinking of replacing these two bearings. How difficult is that to do? Is there anything that I should be doing/changing while I am in there?
TIA,
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Fri Nov 10, 2006 5:25 pm    Post subject: Reply with quote
Do you mean that something is grinding while the car idles in neutral?
isuras2
PostPosted: Fri Nov 10, 2006 6:03 pm    Post subject: Reply with quote
Sometimes there is some grinding in neutral or straight, but mainly during left turns, moreso on hard left turns.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
augidog
PostPosted: Fri Nov 10, 2006 10:42 pm    Post subject: Reply with quote
uh oh
http://www.924board.org/viewtopic.php?t=20771&sid=24610436ec1624fd4fabfe6234c0d56e
PostPosted: Sat Nov 11, 2006 4:33 am    Post subject: Reply with quote
But only when the car is rolling? If so, bad wheel bearings.
isuras2
PostPosted: Sat Nov 11, 2006 5:18 am    Post subject: Reply with quote
Rasta Monsta: I have replaced wheel bearings in the rear so it shouldn't be those.
augidog: I saw your post which made me think of my tranny issues. I figure with winter coming up, I could have the car out of service for a while while I figure this out.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
