Clicking from engine
isuras2
PostPosted: Tue Nov 07, 2006 7:39 pm    Post subject: Clicking from engine Reply with quote
I have a clicking from the engine. It is in the front and sounds like from cam pulley. I have checked and adjusted (if needed) the valves while hot to make sure they are set correctly...and they are. Would they still have some valve slapping? Could it be something else? I have noticed that the edge of the timing belt is hanging off the cam pulley by about 1-2 mm. I don't know if that would be a problem or not.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Tue Nov 07, 2006 8:06 pm    Post subject: Reply with quote
I found that the tensioner pulley will tighten the belt if you rotate it in either direction.
However in one direction it scrapes against the motor after tightening it up.
So I obviously tighten it the other way.
This might just be my motor or is this normal.
Could be your problem?
968rz
PostPosted: Tue Nov 07, 2006 10:49 pm    Post subject: Reply with quote
There will always be some noise from solid lifters.
The timing belt hanging off is not right but should not cause a problem (might have to space the pulley out a bit), the noise could be the ALT or PS belt (if its up front) check these well as the pulley side of the belt could get a "flap" of belt going and then stop on a pulley were you cant see it. Also you can take the other belts off to narrow it down.
Rick
93 968 coupe Amazon Green 4spd Tip (my DD)
924guy
PostPosted: Wed Nov 08, 2006 12:29 pm    Post subject: Reply with quote
are you sure its not the valve cover nut you lost?
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
ushawk1
PostPosted: Wed Nov 08, 2006 3:23 pm    Post subject: Reply with quote
Have you cleaned out your oil tube over the cam?
On all the 924's I ever owned the drivebelt always hung out about a millimeter or so over the edge. The one I have now used to tick at start up and higher RPM. You could try switching oil weights. When I moved to the cold, bleak, dark, depressing, cold, rainy, (and did I mention cold?) state of Washington, I had to switch from 20w50 to 10w40. That ended the ticking for me.
Summer please come six months early.
Shut up fool, those are mine.
Slam
PostPosted: Thu Nov 09, 2006 11:37 am    Post subject: Reply with quote
IIRC the tensioner should be rotated clockwise to tension the belt. We've found that the belt walks to the outside (front) of the cam pulley when the tensioner is failing.
HTH
