isuras2
Posted: Tue Nov 07, 2006 4:55 pm Post subject: Hatch Strut Measurements |
Does anyone have any measurements of the hatch struts? I am looking for compressed length, stroke length, extended length, rod end pin hole dia and base end ball stud dia? _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
-nick
Posted: Wed Nov 08, 2006 5:09 am Post subject: |
Not sure, but you won't find any generic struts that have the electrical connections for the rear defrost.
You can pick up a pair of stock struts with the connections for $60 on ebay. _________________ 1980 931S
1991 964 C4 Cabriolet |
Posted: Wed Nov 08, 2006 6:10 am Post subject: |
There is also an electrical connection that turns on the cargo light when the hatch is open.
JB 924
Joined: 03 Apr 2006 Posts: 606 Location: Hessen, Germany
Posted: Wed Nov 08, 2006 3:37 pm Post subject: |
You better appreciate this! Went out to the shed twince with a flashlight to get the struts and a Schieblehre.
Anyway, here are the measurements:
Holy crap, try compressing one of these and take a measurement at the same time!
Okay, never mind. I can't compress it. If I slip, it'll rip my balls off.
I'll give you the other measurements:
Length of body of strut (black part) - 14 1/8", including the plastic part that holds the ball
Extended length - 26 1/2"
Length of Rod (including plastic part that holds the ball) - 12 5/16"
Both ball pin holes are exactly 1cm (when you measure in line with the
rod)
Hope this helps,
Jens
PS: the measurements could be 1/16" off. Measured in the dark. |
Slam
Posted: Thu Nov 09, 2006 11:40 am Post subject: |
| Quote: | | PS: the measurements could be 1/16" off. Measured in the dark |
I could say so much...
At least you didn't endanger your balls.
 _________________ '88 944 Auto - may or may not resurrect |
JB 924
Posted: Thu Nov 09, 2006 1:47 pm Post subject: |
It wasn't aaaalll dark! I measured in front of the screen, but there is no light. |
