front crank seal on an early '77
geddes66
PostPosted: Tue Oct 17, 2006 12:53 pm    Post subject: front crank seal on an early '77 Reply with quote
I am getting as many problems fixed on my son's car as I can while he's away at Navy boot camp. Transmission is fixed, lights now pop and drop stereo is re-installed adn the waterleak (rain) is almost gone. That sort of thing.
The car has a substantial leak at the front of the engine, it has had it since I bought it about 5 years ago for 500.00. I am reasonalbly sure it is the front seal.
How hard is it this to change this seal? Can I pull the seal without pulling more than the front pulley's (plus a little, of coarse)?
The Porsche is now my son's, my car is cooler, slower but cooler.
PostPosted: Tue Oct 17, 2006 1:07 pm    Post subject: Reply with quote
I'm thinking:
alternator belt
a/c belt
front pulley
timing belt cover
timing belt
crankshaft cam belt drive
oil pump (the seal is in the oil pump)
PostPosted: Tue Oct 17, 2006 2:56 pm    Post subject: Reply with quote
That sounds about right to me to except shouldn't have to remove the oil pump.
It is an easy enough job.
Make sure your crankcase breather is not blocked as the pressure will push the oil out the seal.
I replaced 3 seals before I found this out.
On US cars the crankcase breather hose connects to the air box. On euro spec they connect to the join in the rubber boots to the throttle body.
The large hose has an orifice in it near the motor which gets blocked.
Chrenan
PostPosted: Wed Oct 18, 2006 12:09 am    Post subject: Reply with quote
You do not need to remove the oil pump, just the pulley. The job will be easier with a seal removing tool, and the proper circumference piece of pipe to tap in the new seal.
-nick
PostPosted: Wed Oct 18, 2006 2:49 am    Post subject: Reply with quote
If you go through all that, you might as well pull the pump and replace the $2 oil pump gasket too! Especially if you've got a leak from that area to begin with.
1980 931S
1991 964 C4 Cabriolet
PostPosted: Wed Oct 18, 2006 8:20 am    Post subject: Reply with quote
I agree, plus the seal is much easier to remove on the bench and you do not have any chance of damaging the sealing area on the crankshaft.
geddes66
PostPosted: Wed Oct 18, 2006 1:55 pm    Post subject: Reply with quote
Thanks for all the replies all. It has been a big help.
