Where to Route Line for Boost Gauge
PostPosted: Wed Oct 18, 2006 1:22 am    Post subject: Where to Route Line for Boost Gauge Reply with quote
For those who have done it, where did you go through the firewall?
TIA
rasta
flosho
PostPosted: Wed Oct 18, 2006 1:52 am    Post subject: Reply with quote
Theres a whole below the brake booster about 12" down with about 4 or 5 other wires going through it... from the inside its a few inches up from the clutch pedal. I just fed it through there.. You may need to get a wire coat hanger and straighten it out and use that to feed it through there and make sure it doesn't get wrapped around anything.
[This Space For Rent]
PostPosted: Wed Oct 18, 2006 2:37 am    Post subject: Reply with quote
I used the thin plastic line that came with my gauge and fed it through a grommet near the cold start valve. 3rd pic here - http://www.924board.org/viewtopic.php?t=11407&start=2
PostPosted: Wed Oct 18, 2006 5:25 am    Post subject: Reply with quote
Smoothie wrote:
I. . .fed it through a grommet near the cold start valve.
Interesting pic. . .that hole was empty? I bet it's for a GT boost gauge. Those nutty krauts!
PostPosted: Wed Oct 18, 2006 8:52 am    Post subject: Reply with quote
You can see the location I used here (its the black braided hose):
http://im1.shutterfly.com/procserv/47b5db10b3127cce91b21c27dff500000016108AZuGrlozZtE
Aussie931
PostPosted: Wed Oct 18, 2006 8:04 pm    Post subject: Reply with quote
I found that the easiest was to drill a small hole next to the grill for the fan motor, place a grommet in it and pass the tube through there. Its pretty easy to access once you have the console off.
1979 Series 1 924 turbo
