P924
Posted: Sun Oct 08, 2006 8:41 pm Post subject: Turbo WUR |
My 924 NA has a turbo warm up regulator, but how should I connect it to the intake manifold? Do I have to buy one from a 931 now?
Who can help me?
greetz _________________ 924 1981
911T 2.2 |
Posted: Mon Oct 09, 2006 12:48 am Post subject: |
To get the full throttle enrichment part of it functioning...hook-up to any vacuum source downstream of the throttle valve. _________________ "..it's made in Germany. You know the Germans always make good stuff."
P924
Posted: Tue Oct 10, 2006 5:33 am Post subject: |
anyone has a schedule how i can hook it up ? _________________ 924 1981
911T 2.2 |
jurasT
Posted: Sat Oct 14, 2006 1:09 am Post subject: |
I do not know about the turbo WUR but the audi WUR has to be connected to the same pipe as goes to the ignition distributor (the pipe is before the throttle).
Otherwise it would be enleanment instead of enrichment under load... |
Posted: Mon Oct 16, 2006 12:09 am Post subject: |
No, the WUR with full load diaphragm's vacuum line hooks up to an intake manifold vacuum source downstream (after) the throttle valve. Here <click> is the vacuum line diagram for an '80 931. It has 2 vacuum lines to the distributor. The one that the WUR T's into is sourced from the large vacuum line that originates from manifold vacuum after the throttle.
The Bosch/SAE "Automotive Electric/Electronic Systems" book shows only one type of WUR with enrichment. It runs lean when vacuum is high (idle and steady cruise) and rich when vacuum drops (opening and full throttle). So unless the WUR has been messed-with (as in vent and vacuum points swapped (which is very unlikely)), hook-up the WUR after the throttle. _________________ "..it's made in Germany. You know the Germans always make good stuff."
