is over boost bad?? even if just for a second
porsche.racer
PostPosted: Thu Oct 12, 2006 3:51 am    Post subject: is over boost bad?? even if just for a second Reply with quote
I have a boost controller and was trying to set it up and ended up OVER boosting for a second - then the waste gated or bosst controlerer dumbed all my boost. But, seemed ok after? Could this have done damage. I boosted to about well... my gauge goes to 15psi and I went by it some to 17-18-19 maybe not sure where - only for a second?? Thanks
1987 911 3.6L Carrera with LSD
1986 944 Turbo (Track)
1972 911 3.0L Turbo Look
1988 944
100's of good used parts MUST GO
Check me out on EBAY I.D. porsche.racer
PostPosted: Thu Oct 12, 2006 3:59 am    Post subject: Reply with quote
You are probably OK, but if you are going to continue "experimenting," you should bench test your boost controller switch, which should kill the fuel pump when actual intake pressure exceeds 15 PSI. Sounds like you need a functioning one!
PostPosted: Thu Oct 12, 2006 7:10 am    Post subject: Reply with quote
You better fix that boost-controller.
If you want to experiement with boost, why not by a knock-link knock detector ? It doesnt cost that mutch. And can save you a lot of money..
Kenodog
PostPosted: Thu Oct 12, 2006 1:30 pm    Post subject: Reply with quote
When you get detonation you'll know it.
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
