Question on coolant afraid of answer....
Eturbo924
PostPosted: Wed Oct 11, 2006 12:44 am    Post subject: Question on coolant afraid of answer.... Reply with quote
Hey it has been some time since I bleed the system 924s. When you rev the engine up (cap off) and bleeder plug out... then let the revs fall... should there be any back flow into the coolant bottle?
See it would make sence to me that the water pump is sucking harder and thus causes a slight vacuume in the radiator... and when releaved back flows into bottle.
Just do not want to hear some thing like... head gasket.
Have done this work in the past and could do it again. But would rather avoid it if not needed.
thanks
Eric
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast!
PostPosted: Wed Oct 11, 2006 3:31 am    Post subject: Reply with quote
that is normal to have a higher level in the bottle when engine is idling, rather than revving.
3 928s,
Eturbo924
PostPosted: Wed Oct 11, 2006 4:25 am    Post subject: Reply with quote
That is what I hoped.
Thanks
1992 968
2003 C4S
Drive Fast!
PostPosted: Wed Oct 11, 2006 10:18 am    Post subject: Reply with quote
Bleed the system with the coolant tank cap on tight for best results.
Eturbo924
PostPosted: Wed Oct 11, 2006 12:13 pm    Post subject: Reply with quote
Yeah I normally do that but I wanted to watch the coolant and see if I had cleared the system out.
Alas there is still crap in it. I need to do it again. At least the oil is clean and clear now. Nothing worse than a car sitting with old coolant, gas and oil in it for two years.
Oh wait I know what is worse. One that had the rear hatch smashed and then was filled with leaves, bees, mold, water and spiders!
At least most of it is where it should have been now. Just alternator, coolant flush and brakes left.
Weeeee!
1992 968
2003 C4S
Drive Fast!
