Fuel Pump issues?
isuras2
PostPosted: Fri Oct 06, 2006 8:34 am    Post subject: Fuel Pump issues? Reply with quote
I believe that the fuel pump is going bad. I can't hear it being louder, but while driving under most conditions, the car seems to lose power for a split second. This happens moreso on big bumps, but also on left turns sometimes. It could be a connection, but I tried pulling/wigling the wires to both pumps and everything was fine. What are the symptoms of a bad fuel pump besides the louder noise?
Thanks,
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Fri Oct 06, 2006 8:41 am    Post subject: Reply with quote
When mine went, the first symptoms were crappei running and changing sound from the fuel pump that coincided with the poor running. I verified it with a CIS fuel pressure tester - that showed changes in primary (aka- "system") pressure that coincided with the sound changes.
augidog
PostPosted: Fri Oct 06, 2006 9:36 am    Post subject: Reply with quote
Mine started blowing relays.
It sounds like a fuel filter issue to me.
Min
PostPosted: Fri Oct 06, 2006 9:43 am    Post subject: Reply with quote
Could also be rust in the tank blocking the inlet, which would be why bumps/turning would make a difference.
Min
isuras2
PostPosted: Fri Oct 06, 2006 10:30 am    Post subject: Reply with quote
I don't like the sound of that. I will change the filter this weekend though.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Fri Oct 06, 2006 5:16 pm    Post subject: Reply with quote
Changing the main fuel filter won't help with rust in the intake, (but it's worthwhile doing anyway). If you've got an in-tank LP pump you can remove that and see if there's anything clogging the strainer mesh...
PostPosted: Sat Oct 07, 2006 3:11 pm    Post subject: Reply with quote
Sound like an ign system failure about to occur to me.
isuras2
PostPosted: Wed Oct 11, 2006 3:13 am    Post subject: Reply with quote
Like distributor?
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
Eturbo924
PostPosted: Wed Oct 11, 2006 6:27 am    Post subject: Reply with quote
Two things to check if you have not yet
The fuel pump relay and the ignition switch.
Many times the ground wire begins to pull out from the back of the relay board and you hit a bump... the wires bounce and you get an intermittant signal to the relay.
Same thing happens to the ignition switch... but this is more wear and tear. I have had the circuit that the radio is on go out on mine. Funny when that happens... I thought dang! My new radio is toast already!
I would suggest going through the tests in the haynes manual on the pump and change the filters anyway. It is always good to have clean fuel Though it is a bit-ch to change them. At least for me.
Good luck
Eric
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast!
PostPosted: Wed Oct 11, 2006 7:57 am    Post subject: Reply with quote
I am thinking a bad wire/connection/switch or relay.
Intermittent faults are a cow cos they'll always work at the auto electricians.
isuras2
PostPosted: Wed Oct 11, 2006 9:37 am    Post subject: Reply with quote
It can't be the radio as I don't have one installed. I will check the relay and wires.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
Eturbo924
PostPosted: Wed Oct 11, 2006 9:45 am    Post subject: Reply with quote
Haha I did not mean the radio screwed anything up. What I meant was the ignition switch can fail. Some times it is the start position some times it is the run and different circuits can fail. LOL! Radio no in your car... that is funny.
1992 968
2003 C4S
Drive Fast!
PostPosted: Thu Oct 12, 2006 2:37 am    Post subject: Reply with quote
Howdie,
if you carry a lot of Keys on your k-ring the ignition switch will be dead much earlier.
By the way, the noise from the fuel-pump doesnt bother me at all.Mine is singing in diffrent tunes since about 15 years! i think i will die before the dammed thing.
PostPosted: Thu Oct 12, 2006 6:07 pm    Post subject: Reply with quote
LOL!
