Cold start problems
DebbOR
PostPosted: Tue Sep 26, 2006 7:19 am    Post subject: Cold start problems Reply with quote
Hi. I am a new member here. Over this past week end I aquired a '79 924, 5 speed. Mechanically it runs good, except for 1 thing, it has a hard idle when first started, once warmed up it runs fine. The cold start valve was replaced by the PO, and I am wondering if it is the auxillary air regulator that could be causing the troubles. Any ideas, help, suggestions will be greatly apperciated.
Thanks,
Deb
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Tue Sep 26, 2006 9:39 am    Post subject: Reply with quote
Deb, welcome to the board! If you haven't considered the Oregon chapter of PCA yet, I recommend that.
What is the history of the car? I would start with plugs, wires, cap & rotor, and see if your problem improves. I would also run exclusively Chevron gas, my 79 was very fussy about fuel, and ran as you describe on any other type...and maybe an extra bottle of Techron in each of the first few tanks as well. If you still have a rough idle after these steps, check back.
Rasta
PS, Oh yeah, check all rubber intake boots, and replace if hard/brittle.
Chrenan
PostPosted: Tue Sep 26, 2006 9:45 am    Post subject: Reply with quote
I would look for a vacuum leak, also test the Auxiliary Air Valve and replace if required.
koolkarateguy
PostPosted: Tue Sep 26, 2006 11:14 am    Post subject: Reply with quote
I was having the same problems as you. I cleaned the auxiliary air regulator and made sure it was working, put fresh plugs in the car (big improvement on the top end)and air filter. But what made the most difference as far as starting goes was when I cleaned the throttle body. I used almost a full can of throttle body cleaner. It was really carboned and gummed up. After that I increased the idle and now it usually starts on the first turn of the key, idles smooth and doesn't sputter and hesitate when it's cold. Hope this helps .
1979 N/A 924
Charlane
PostPosted: Wed Sep 27, 2006 9:57 am    Post subject: Reply with quote
Oh, that K Jetronics system takes some getting used to! I had a hard time initially because there has to be vacuum for the ignition to 'open fire'. So, if your boot over the air flow sensor is cracked, or if there is any excess air leaking into this vacuum, easy starting will be at a minimum. Check all your boots and hoses and replace these if there is any question~!
Electra is Here......
One 1980 924 Turbo
One 1990 KZ1000P (CHPS) Motorcycle
One 1984 244 Turbo Volvo (B21FT) (I installed this engine myself)
One 1977 240D Mercedes Benz
One 1970 Chevy Impala
John Brown
PostPosted: Wed Sep 27, 2006 11:10 pm    Post subject: Re: Cold start problems Reply with quote
Thanks,
Deb
Fellas. All the suggestions are 'good ideas'. But Deb says the problem is a 'hard idle' when first started.
Deb - What do you mean by 'hard idle'? Rough running, low rpm, ?? Does it do this when first started all the time, both hot and cold? Or only when the engine is started from cold?
And yes, the auxillary air valve is a most likely suspect at this time. It can be tested.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
DebbOR
PostPosted: Thu Sep 28, 2006 12:04 am    Post subject: Cold start problems Reply with quote
Thanks for all the replies. Yes, when I first start the car, it idles rough, and the RPMs are low, and only when the engine is cold. Once it is warmed up it runs fine.
I have also checked for vacuum leaks and have found none.The PO had replaced the plugs & rotor. The wires will need to be replaced in the future. As far as gas goes, the PO said he had just filled it with gas from 76..premium,and I *only* use gas from Chevon.
Again thanks!
PostPosted: Thu Sep 28, 2006 1:23 am    Post subject: Reply with quote
John-
Thanks for the 'vote of confidence!'
rasta
P.S. The 'good ideas' come from this. . .with my old 79, I found that any tuning issues had exaggerated effects when the car was cold!
