LeeXIX
Joined: 09 Feb 2006 Posts: 19 Location: Cleveland, Ohio
Posted: Thu Sep 21, 2006 7:43 am Post subject: large aluminum piece on back of trans |
Does anyone know the reason for that large aluminum piece hanging on the back of my 77's 4speed trans? I do not see any other reason for it other than that it blocks the bolts I would need to remove if I had to pull the endcap off (not that I am planning on the soon).
It looks like that if I took that piece off I would have enough room to do a clutch job (my car has 100,000 + miles on it) without too much trouble.
I figure it must be there for a reason but for the life of me I cannot think of one. _________________ I have a 924 (yellow) Porsche since I lost my 1971 914 in my divorce. She threw out everything except the shell of the body. |
-nick
Posted: Thu Sep 21, 2006 9:31 am Post subject: |
Transfers impact energy through the drivetrain if hit from behind, leaving you more intact Also keeps a large impact from plowing in and rupturing the fuel tank. It doesn't weight much and there's no reason to leave it off.
With a 4-speed trans, I believe you can pull the clutch without removing the transaxle. If you remove the alloy piece, you should have space to slide the torque tube + trans back far enough to get at the clutch. Marginally easier than pulling the trans off completely. Still a pain. _________________ 1980 931S
1991 964 C4 Cabriolet |
LeeXIX
Posted: Fri Sep 22, 2006 6:45 am Post subject: re: aluminum piece |
Thanks for the info. I'll just keep it on until I need to replace my clutch.
But that all hinges on me getting a new fuel pump (it's on backorder through Performance Parts).  _________________ I have a 924 (yellow) Porsche since I lost my 1971 914 in my divorce. She threw out everything except the shell of the body. |
geddes66
Joined: 10 May 2003 Posts: 129 Location: Bakersfield CA
Posted: Tue Sep 26, 2006 1:24 pm Post subject: |
That is good info nick. I have my son's tranny about 75% re-installed, I had to pull it to install a rollpin in the 3-4 shift fork, and will definately put it back in. _________________ The Porsche is now my son's, my car is cooler, slower but cooler. |
