356speedster
Posted: Tue Sep 19, 2006 2:21 am Post subject: Gearbox origin? |
We all (I guess) know that the engine block origins from the Audi 100 and VW LT.
But wich Audi/VW car does the "Audi" gearboxes origin from?
I have searched but the closest I find is "gearbox of Audi origin".
But I want to know more.... please enlighten me  _________________ 1982 Porsche 924 na My 924 blog
1990 Porsche 928 S4 My 928 blog
1995 Fiat barchetta
2007 BMW 318d M-Sport
2010 Volvo V50 |
Posted: Tue Sep 19, 2006 3:15 am Post subject: |
audi 5000, and the audi fox appear to be close. _________________ 3 928s, |
Posted: Tue Sep 19, 2006 12:59 pm Post subject: |
and probably most later model front-wheel drive Audis with the motor mounted north-south as well. Some Audis came with a 6-speed transaxle that might be cheaper than the 6-speed 968. _________________ 1979 924 (Gone to a better place)
Badeu
356speedster
Posted: Tue Sep 19, 2006 9:57 pm Post subject: |
| Peter_in_AU wrote: | | and probably most later model front-wheel drive Audis with the motor mounted north-south as well. Some Audis came with a 6-speed transaxle that might be cheaper than the 6-speed 968. |
Are you saying that an Audi 6-speed gerbox would fit in 924?
That would be very interessting. Tell me more...  _________________ 1982 Porsche 924 na My 924 blog
1995 Fiat barchetta
2010 Volvo V50 |
Posted: Wed Sep 20, 2006 3:32 am Post subject: |
looks like you might have to remove the spare tire well for enough room, and would have to look at it first to verify that the bellhousing pattern is the same. _________________ 3 928s, |
-nick
Posted: Wed Sep 20, 2006 3:40 am Post subject: |
It would be nice. I know the 968 bellhousing is different and won't mate up to the 5-spd torque tube. Something tells me that the other Audi 6-spds are probably the same pattern as the 968. For the 968 conversion, I believe you have to use the 968 fuel tank too. Not sure if you have to dip into the spare wheel well. This stuff should be documented over on rennlist. _________________ 1980 931S
1991 964 C4 Cabriolet |
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Wed Sep 20, 2006 7:40 am Post subject: |
you'd have to look at the 968 g/b's ratios tho... _________________ '86 944 |
Badeu
Posted: Wed Sep 20, 2006 8:51 am Post subject: |
I've found an audi 6-speed gearbox on ebay.de with 3 pics. One of them was the front of the bell housing. Ecxept for three holes, all things are ok ( design, holes, concept, etc... )
the side : there is different holes for gearbox mounts but it's not really a problem, and connection to shift lever is the same as our audi type gearbox.
the size : it is only few centimeters longer but the car has room to accept it. |
JB 924
Joined: 03 Apr 2006 Posts: 606 Location: Hessen, Germany
Posted: Wed Sep 20, 2006 10:27 am Post subject: |
| You could adapt the Audi bellhousing to the 924 torque tube bellhousing, if you were willing to do the work, but would the axles still fit without modification? Is the transmission only longer in the back, or are the axle "connections" on the transmission more to the rear, too? Cool idea, though. |
