cam upgrade
Goto page 1, 2, 3  Next
germ924
PostPosted: Fri Aug 11, 2006 4:47 pm    Post subject: cam upgrade Reply with quote
what can i upgrade my cam with and gain some horses and not have to do to much to make it work properly, i'm a noob on upgradeing this 924,
I would like to keep it semi stock but have more power. I have port and polished it when I first got it. (blown head gasket), removed emissions and vacuum lines from amplifier.
what more can i do??
StienbargerR
PostPosted: Sat Aug 12, 2006 2:44 am    Post subject: Reply with quote
Integral cams is a good source.
http://www.integralcams.com/924.htm
Someone had one for sale a while ago. There is another post on camshafts right now on one of the threads, so you might want to check that out.
Ryan
1978 924 NA
augidog
PostPosted: Sat Aug 12, 2006 11:21 am    Post subject: Reply with quote
okay-I'll bite- what is with the blue mini air filter gizmos?
flosho
PostPosted: Sat Aug 12, 2006 11:43 am    Post subject: Reply with quote
Just breather filters, those lines probably ran into the stock air box, which is only half existant in the picture..
[This Space For Rent]
germ924
PostPosted: Sat Aug 12, 2006 2:33 pm    Post subject: Reply with quote
thanks steinbarger im gonna go ahead and get the stage 1 it will fit my driving habits closest
ushawk1
PostPosted: Sat Aug 12, 2006 2:40 pm    Post subject: Reply with quote
Sorry, but I nominate that motor for the Dirtiest of the Year Award.
Shut up fool, those are mine.
PostPosted: Sat Aug 12, 2006 3:11 pm    Post subject: Reply with quote
If you want a to not spend alot of money on a cam
see http://www.schneidercams.com/. They offer to grinds of cam
there regrinds though if you keep themadjusted there no problem..
I have one & am gonna get the more agressive grind here next month.
germ924
PostPosted: Sat Aug 12, 2006 4:23 pm    Post subject: Reply with quote
yea i do need to wash her down huh..
thanks for the link joe I'll check it out.
John Brown
PostPosted: Mon Aug 14, 2006 1:00 am    Post subject: Reply with quote
At one time I had the info re Schneidercams for a 924. Dont remember now so, question:
Do they put a hard surface on the cam face? I have known of 924 Schneidercams that have failed apparently because the lobes were ground without adequate hard surfacing. The stock hardening is not very deep. Easy to go through it.
What did you have to do to get the lifter clearance back? The smaller base circle of the re-grind must at least require some new adjusting screws (at $7 each).
How much?
Nice thing about the Integral is it simply drops in. With any luck at all you can use the old adjusting screws.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
PostPosted: Mon Aug 14, 2006 1:29 am    Post subject: Reply with quote
ground cams come with little lifter plates which you put under the tappet ontop of the valve stem to take up the extra clearance
3 928s,
B
PostPosted: Mon Aug 14, 2006 5:47 am    Post subject: Reply with quote
Is that the same with the integral cams also? They made it sound as though it (stage 1) was pretty much a direct replacement.
thanks
B
1979 924 n/a
BAE turbo
5-speed snailshell
Min
PostPosted: Mon Aug 14, 2006 5:50 am    Post subject: Reply with quote
Integral Cam's are not grinds, they are new cam's machined from new billet.
Min
B
PostPosted: Mon Aug 14, 2006 5:53 am    Post subject: Reply with quote
Min
new sounds better - but is it ? or is there noe real difference ?
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Mon Aug 14, 2006 7:09 am    Post subject: Reply with quote
new is better.
when the cam is reground the surfaces the touch the follower need to be rehardend so that they dont wear, if they dont harden it properly the cam with be destroyed quickly and will take all the followers out, not worth it imo
3 928s,
Min
PostPosted: Mon Aug 14, 2006 7:19 am    Post subject: Reply with quote
I had a camshaft reground and not rehardened properly.... I can say new is better. The reground camshaft worn 3 lobes right off.
Min
Page 1 of 3
