DS-777
Joined: 16 Sep 2005 Posts: 134 Location: Michigan USA
Posted: Sun Sep 17, 2006 8:29 am Post subject: Turbo questions. EDIT: BAE Turbo questions |
Well, the other day the turbo install was finished. The car started immediately, but something didn't sound right. There was a lot of noise coming from the turbo and quite a bit of dark exhaust coming out the back.
I'm pretty much assuming this means I need to rebuild the turbo? I was told that wouldn't be necessary. I'm going to contact my924gtc, but I doubt from what I've heard lately that it'll do much good.
On a side note, my dad work in the industrial supplies business, and I was wondering if I could get the parts to rebuild cheaper through him? There wasn't any shaft play or bent fins when I put the turbo in, so I figured the parts needing rebuilding are seals and bearings?
Not trying to be a sob story or pity case, I just had a few questions. _________________ Gone: 1981 silver 924 w/ black int. and a 5 speed. |
Posted: Sun Sep 17, 2006 11:28 am Post subject: |
Dark smoke usually means you are running rich. Does it smell like gasoline?
The smoke would be bluish white and smell like oil if the turbo seals were bad.
Describe the noise that the turbo is making. _________________ White 87 924S "Ghost"
MunkPuppy
Joined: 02 Jul 2003 Posts: 419 Location: New Westminster, B.C., Canada
Posted: Sun Sep 17, 2006 1:06 pm Post subject: |
if it happens that your turbo needs to be rebuilt, don't make the mistake I did and try doing the rebuild yourself. There are quite a number of tolerances that, if not within spec, will make your rebuild completely redundant. I recommend that you remove the turbo yourself and take it to a turbo shop if you believe it to be the problem.
Smoking problems can also be caused by the crankcase breather being plugged. Try cleaning it with carb cleaner or old gasoline prior to an oil change and see if that stops your smoking problem.
But make sure it's oil smoke first, as Paul has already mentioned. _________________ '80 931 FOR SALE
"It's a shame that stupidity isn't painful"
-Anton Szandor LaVey |
DS-777
Posted: Wed Sep 20, 2006 11:31 am Post subject: |
The noise was something else, pretty much unrelated, and its taken care of. Well, the smoke was oil, and the seals on the turbo are bad. It was putting oil into the hotside and inbetween the cold side and center section, but no oil was in the actual cold side or intake.
The impeller and fins are all straight with no shaft play though, so I think I'll only need the seals and maybe the bearings as long as we're in there?
My dad is pretty confidant about being able to rebuild it himself, hes been working with industrial seals and such on all different applications for over 30 years. He was the one who made up the oil lines for me. _________________ Gone: 1981 silver 924 w/ black int. and a 5 speed. |
DS-777
Posted: Fri Sep 22, 2006 7:16 am Post subject: |
Beauler? Beauler?
Anyways, yeah, I sent him a message. We'll see. What'd be cheaper, do you think, a rebuild on this old rayjay unit, or a new turbo to fit the BAE flange? _________________ Gone: 1981 silver 924 w/ black int. and a 5 speed. |
Andrew NZ
Posted: Fri Sep 22, 2006 8:52 am Post subject: |
| DS-777 wrote: | Beauler? Beauler?
Anyways, yeah, I sent him a message. We'll see. What'd be cheaper, do you think, a rebuild on this old rayjay unit, or a new turbo to fit the BAE flange? |
If you find where to get the seals etc could you let me know please? The Rayjay seems to be a very good turbo for it's age, but if you do change you might be able to get something with a built in waste gate, as your sydtem doesn't have one from memory. _________________ Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz |
