Posted: Mon Sep 18, 2006 1:29 am Post subject: |
A free-er flowing exhaust is better for hp at higher speed, but a more restrictive exhaust is better for torque, so exhaust systems are designed to provide a compromise between the two. There's a device - an exhaust tip with a variable spring-loaded flap that stays more closed at low speeds to provide more torque and gradually opens up as speed increases to improve HP at higher speeds. I don't have any personal experience with it (and it wouldn't make sense to use on a turbocharged car because the turbo provides resistance at lower speeds and becomes more free-flowing at higher), but it makes sense to me for a NA car and should work, but you'd have to change your whole exhaust system to a larger diameter to get the high end HP gain. _________________ "..it's made in Germany. You know the Germans always make good stuff."
