crank roll pin
jjames
PostPosted: Wed Sep 13, 2006 7:51 am    Post subject: crank roll pin Reply with quote
ok people, thanks to you I almost have the 924 on the streets! hopefully, the last obstical is this timing belt pully problem. I removed it today to discover that the roll pin that holds it to the crank is sheared off. I can drill it out of the pully but, getting it out of the crank is going to be harder. Any suggestions?
PostPosted: Wed Sep 13, 2006 10:20 am    Post subject: Reply with quote
it is a much softer material than the crank so drilling it out shouldnt be too daunting of a tast,
maybe get your 928 neighbour to give you a hand
3 928s,
jjames
PostPosted: Mon Sep 18, 2006 11:10 am    Post subject: help please Reply with quote
i AM HAVEING A VERY HARD TIME FINDING THE PIN THAT HOLDS THE TIMIMNG BELT PULLY TO THE CRANKSHAFT. dOES ANYBODY KNOW WHERE i CAN GET ONE? Sorry for the caps but, I am to lazy to retype it.
PostPosted: Mon Sep 18, 2006 11:26 am    Post subject: Reply with quote
From PET Version 5.0
924 78 MG 1 SG 02 Illustration 102-00
Item 2
Part # 023 255 1
called Tension Sleeve, 4 x 12
3 928s,
jjames
PostPosted: Mon Sep 18, 2006 12:27 pm    Post subject: tension sleeve Reply with quote
thanks again, you have been a very big help to this newbee
