88mm head gasket
leadfoot
PostPosted: Tue Aug 22, 2006 8:48 pm    Post subject: 88mm head gasket Reply with quote
For use with a set of 88mm pistons, what are my head gasket options??
will the stock 931 gasket still do the trick?? I seem to remember there being a couple of mm around the bore last time I replaced the head gasket... Would all this be taken up by crush??
Otherwise what are these like... they're the triple stainless steel gaskets
http://www.sdpc2000.com/cart.asp?action=cart_details
any thoughts??
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
leadfoot
PostPosted: Thu Aug 24, 2006 8:37 am    Post subject: Reply with quote
Ok, so the ID of a new 924 turbo head gasket is 88.5mm...
How much space will it take up during crush??
Does anyone have a used head gasket they can measure the ID of??
thanks...
Leadfoot
leadfoot
PostPosted: Tue Aug 29, 2006 3:16 pm    Post subject: Reply with quote
EDIT : A new REINZ turbo head gasket is much larger at 89.5mm ID...
Leadfoot
Aussie931
PostPosted: Tue Aug 29, 2006 5:20 pm    Post subject: Reply with quote
I fitted 87.5 mm pistons and used a Goetze gasket with no clearance issues. Don't think that another 1/2 mm will make a difference.
1979 Series 1 924 turbo
