Starter Spins Without Engaging Once, Maybe Twice
Charlane
PostPosted: Mon Aug 28, 2006 2:10 am    Post subject: Starter Spins Without Engaging Once, Maybe Twice Reply with quote
And then starts the car. The car starts fine, with the exception of a few vacuum leaks but otherwise, this spinning of the starter without engaging is strange and annoying. It sounds like the gears aren't making contact the first or even second time and then it does but THESE ARE GEARS so that doesn't make sense to me. The gears aren't exactly dynamic like that. Thanks in advance.
Electra is Here......
One 1980 924 Turbo
One 1990 KZ1000P (CHPS) Motorcycle
One 1984 244 Turbo Volvo (B21FT) (I installed this engine myself)
One 1977 240D Mercedes Benz
One 1970 Chevy Impala
Min
PostPosted: Mon Aug 28, 2006 2:25 am    Post subject: Reply with quote
Sounds like a sticky starter solenoid, if the solenoid doesn't move the starter gear forward into the flywheel ringgear, the starter will just spin.
Min
PostPosted: Mon Aug 28, 2006 7:50 am    Post subject: Reply with quote
Min is right.
The gear on the starter moves to engage the flywheel teeth.
This is done by the solenoid.
PostPosted: Mon Aug 28, 2006 8:41 am    Post subject: Reply with quote
What's weird though is the part of the solenoid that pulls in (piston, armature, whatever you want to call it), first levers out the starters' gear to engage with the flywheels' ring gear, then at the end of its' travel it closes the switch to activate the starter motor. (If the starter motor is being activated, the solenoid should have already levered out the gear - that happens before the switch is closed.) -So it seems the solenoid is functioning correctly and the problem is actually with part of the starter itself (specifically the "Bendix").
Min
PostPosted: Mon Aug 28, 2006 1:00 pm    Post subject: Reply with quote
I'd suggest pulling the starter out and benchtesting it. I agree with smoothies diagnosis, If the solenoid isn't working, the starter itself wouldn't engage. I thought about that after I posted the first time.
Min
PostPosted: Mon Aug 28, 2006 10:52 pm    Post subject: Reply with quote
The bendix drive may need greasing... remove, clean, and grease/check for proper motion...
