Charlane
Joined: 25 Jul 2005 Posts: 50 Location: San Antonio, TX
Posted: Mon Aug 21, 2006 3:53 am Post subject: Oil Seal |
I've got oil leaks and I haven't really put my finger on the exact source. I did ratchet the main bolts to torque and this slowed leaking down some so I'm thinking that it is from the main seal somewhere. Does anyone have any discussion on what their day was like changing out this seal? Info please.
Thanks in advance. _________________ Electra is Here......
One 1980 924 Turbo
One 1990 KZ1000P (CHPS) Motorcycle
One 1984 244 Turbo Volvo (B21FT) (I installed this engine myself)
One 1977 240D Mercedes Benz
One 1970 Chevy Impala |
Joined: 23 Apr 2006 Posts: 1650 Location: Sydney, Australia... mate!
Posted: Mon Aug 21, 2006 1:07 pm Post subject: |
FWIW I'm just waiting for mine to come back after having the crankshaft seals replaced - so don't stop your search before looking at them also...
Gavin. _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Posted: Mon Aug 21, 2006 4:59 pm Post subject: |
I did the front crank seal several times before finding out the crankcase breather was blocked.
Easy enough though. _________________ Porsche 924 1984 (UK import) NA
Posted: Mon Aug 21, 2006 11:39 pm Post subject: |
| Ozzie wrote: | I did the front crank seal several times before finding out the crankcase breather was blocked.
Easy enough though. |
Yeah, checked that - but it was the actual seals. Doh. _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
-nick
Posted: Tue Aug 22, 2006 1:31 am Post subject: |
| Are you suspecting the front crank seal, or the rear? Front is do-able, rear means pulling the engine. |
Posted: Wed Aug 23, 2006 5:37 pm Post subject: |
Charlane, what do you mean by 'main bolts' and 'main seal'?
If main seal means crankshaft seal there are no bolts that will affect how it behaves.
Are you refering to the head gasket...? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
