air box help needed
germ924
PostPosted: Fri Aug 11, 2006 1:06 pm    Post subject: air box help needed Reply with quote
there is a hose that connects from the bottom of my airbox to the motor,
is this needed to be connected? (I circled it in Red) and what does it do. i went ahead and disconnected it and put a small filter on the end because it didnt seem to make a difference. is it bad to do this...?
to move the fuel distributor to left side what distributor do i need to make this happen and what problems will i run into.. What i'm trying to do is seperate the fuel Dis. from my airbox so i can run direct air.. maybe a cold air intake set-up
How much Hp will I gain if I do a cold air intake?
http://i92.photobucket.com/albums/l14/germ924/home014h-1.jpg
Benino
PostPosted: Fri Aug 11, 2006 1:15 pm    Post subject: Reply with quote
its fine to put that filter there. That hose captures blowby fumes from the crank and directs them into the intake so they will reburn. In CA you'd have to have that connected to pass the visual part of the smog check. Shouldn’t affect how the car runs
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
