| Which should I replace first? |
| Radiator |
75% |
[ 3 ] |
| Water Pump |
25% |
[ 1 ] |
| Total Votes : 4 |
cookcj
Joined: 25 Jul 2005 Posts: 13 Location: Kittery, Maine / Portsmouth, New Hampshire
Posted: Mon Jul 25, 2005 7:51 am Post subject: My 1980 924 won't stay cool ...... |
| All right ya'll here's the restoration quandry of the week. In the restoration of my 1980 Porsche 924; I have repalced the alternator and it's associated belt, the battery, and the radiator resevoir. However, my 924 overheats in approx. 10-15 mins after start-up while in park. Noting that this may possibly indicate a 'dead' thermostat, I; like any other kid from Florida who is used to taking out their thermostat in the summer; simply allowed the engine to cool and removed the thermostat (and reconnected all the piping). When I re-started the car, it over heated in apporx 20 mins. Is there a way to determine if my water pump is not pumping enough (water moves when the engine is running { even before it gets hot since I removed the thermostat }) or if my radiator is blocked and thereby reducing the surface area available for cooling? And finally, which do ya'll recommended I replace first, the radiator or the water pump? |
tj924
Joined: 15 Jul 2004 Posts: 957 Location: Toowoomba, Queensland, Australia
Posted: Mon Jul 25, 2005 8:52 am Post subject: |
OK, firstly put your location in your profile so we know where you are. Second, add your vehicle type to your signature for future posts. Both of these will help others to help you.
In terms of your poll, start with neither! Replace the thermostat with a new, lower temp one as it is there for a reason. Is your radiator fan working properly? Mine kicks in when the temp hits about 1/2 way & I don't have a lower temp thermostat.
Check the waterpump for leaks out of the weep hole on the front just under the pulley. If there are none check if there is any play in the shaft by trying to wriggle it up & down. If it is leaking or there is play in the shaft, replace it.
If your waterpump is OK & you have a new thermostat & you still have the problem, pull the radiator & have it tested.
Also, get yourself a Haynes manual if you don't already have one. Make sure it isn't the older edition. Should have a greenish cover rather than an orange/red one. This stuff is covered in the Haynes. _________________ TJ
Silver '82 924 NA 5-Speed Manual |
tj924
Posted: Mon Jul 25, 2005 8:57 am Post subject: |
Oh, and welcome to the board! _________________ TJ
augidog
Posted: Mon Jul 25, 2005 9:02 am Post subject: |
Put your thermostat back in!!! We looked at removing it in the past. The piping configuration will not allow it to operate properly with it removed.
Your probally not getting enough flow with it out. _________________ 1978 924 95 mile daily driver.
Posted: Mon Jul 25, 2005 9:31 am Post subject: |
I agree. Your whole problem is probably the thermostat. The old one was probably stuck closed, then you only saw a slight improvement with it removed. You should see it improve much more with a new and correct 924 thermostat in place (it should have an extra disc at the bottom - this causes all the coolant exiting the head, to flow through the radiator when the thermostat opens). Without the right thermostat, most of the flow goes right from the head to the pump and back into the engine without going through the radiator. _________________ "..it's made in Germany. You know the Germans always make good stuff."
cookcj
Posted: Mon Jul 25, 2005 9:34 am Post subject: Ok, a few follow-on question then ... |
(1) How does removing a device that restricts liquid flow through a heat exchanger reduce the heat removal charactoristics of the system? It seems to me that by sending maximum flow though the heat exchanger would result in the maximum amount of cooling. (2) I have noted other members talking about replacing the radiator in their vehicle with a 944/928 radiator and how it requires manufacture of speical brackets. Does anyone know anything about this? (3) If the pump is bad, how much should I expect to realistically pay for a replacement? (4) Is there anyway to install a manual 'fan on' over-ride switch? (Between the thermocouple and the fan relay maybe) (5) What's up with the whole warm/hot - restart switch thing I keep hearing about? and finally (6) Why is my 924 hard to restart when the engine is warm?
Oh yeah, thanks for the warm welcome to the group. I'm orginally from Orlando, Florida but the US DoN has me stationed in Maine at the Portsmouth Naval Shipyard _________________ 1980 924 N/A Automatic w/ Factory Air
(First Porsche and first European Auto Rebuild) |
D Hook
Posted: Mon Jul 25, 2005 9:49 am Post subject: |
Per #1--Due to the way the cooling system is designed, it's actually detrimental to remove the thermostat. If you don't have a Haynes yet, you'll have to take the word of the board members who reply. I think it's covered in the FAQs maybe.
I don't think you'd have to replace the pump unless it's leaking.
Do you know where the car has spent the last couple years? Was it in Florida or up in the East where you are now? That may make a difference in how the cooling system was maintained.
I've put a lower temp thermostat in and a lower temp fan thermostat so the fans will turn on sooner than stock. I've also had the radiator cleaned out and rebuilt about 15 years ago. My gauge would go above 1/2 way before the fans would kick on. Then I cleaned my grounds under the dash and cleaned the plug that goes into the back of the gauge. The needle doesn't go above the middle line anymore. Fans kick on at about the first mark. Temp stays right at the first mark on the highway and just above in the city.
You may have to wait and get the Haynes and read it over. I'm just telling you what worked for me. YMMV. _________________ '80 924 n/a SOLD |
Posted: Mon Jul 25, 2005 10:00 am Post subject: Re: Ok, a few follow-on question then ... |
| cookcj wrote: | | (1) How does removing a device that restricts liquid flow through a heat exchanger reduce the heat removal charactoristics of the system? It seems to me that by sending maximum flow though the heat exchanger would result in the maximum amount of cooling. |
I see we have a skeptic. If you had a copy of the Haynes manual (and I had mine here), I could give you the page number for a diagram that makes it clear (after 5-10 minutes of staring at it). Basically, you have the thermostat housing at the front of the head. Out of it are 2 passages, one up to the radiator and one down to the water pump. When the thermostat is closed (in the up position, coolant flows down to the water pump and back into the block. When the thermostat is opened (in the down position (the disc at the bottom of the thermostat also moves down to seal the passage back to the water pump)) coolant flows up to the radiator. Without the correct type of thermostat installed, when the thermostat opened (also if no thermostat's in place at all), it would allow flow both up to the radiator and down to the water pump at the same time. Then given that the coolant will flow more freely through the path of least resistance, most of it will go down to the water pump and less of it will go up and through the radiator. _________________ "..it's made in Germany. You know the Germans always make good stuff."
cookcj
Posted: Mon Jul 25, 2005 10:09 am Post subject: Re: Ok, a few follow-on question then ... |
| Smoothie wrote: | | cookcj wrote: | | (1) How does removing a device that restricts liquid flow through a heat exchanger reduce the heat removal charactoristics of the system? It seems to me that by sending maximum flow though the heat exchanger would result in the maximum amount of cooling. |
I see we have a skeptic. If you had a copy of the Haynes manual (and I had mine here), I could give you the page number for a diagram that makes it clear (after 5-10 minutes of staring at it). Basically, you have the thermostat housing at the front of the head. Out of it are 2 passages, one up to the radiator and one down to the water pump. When the thermostat is closed (in the up position, coolant flows down to the water pump and back into the block. When the thermostat is opened (in the down position (the disc at the bottom of the thermostat also moves down to seal the passage back to the water pump)) coolant flows up to the radiator. Without the correct type of thermostat installed, when the thermostat opened (or if no thermostat's in place at all), it would allow flow both up to the radiator and down to the water pump at the same time. Then given that the coolant will flow more freely through the path of least resistance, most of it will go down to the water pump and less of it will go up and through the radiator. |
Makes sense; without the themostat, majority flow simply recircs through the engine block and thus bypasses the heat exchanger due to the lower head restrictions in the coolant pump / engine flow path. And the Hayes manual is supposed to arrive via UPS tommarrow. _________________ 1980 924 N/A Automatic w/ Factory Air
Charlane
Joined: 25 Jul 2005 Posts: 50 Location: San Antonio, TX
Posted: Mon Jul 25, 2005 10:23 am Post subject: |
NO! It's not all about the thermostat! This happened to me and some SOB tried to sell me a waterpump job for $500 but I took the car home. What I did was take a $3 tube of die-electric grease and a small paintbrush and brushed on this conductive gel on all of the electrical fan components and electrical components relative to the pumps and cooling. Don't stop there either! I went over all of the spark plugs, coil, all ground, battery terminals, etc. My baby fires right up with just barely a tap at the key. I tightened the belt at the alternator/water pump and used a little belt dressing to keep it nice and resilient. After you have done all of this, test your battery voltage! If you are pulling less than 13 volts, consider increasing your throttle to increase the action from your alternator which translates into your electrical cooling!
One last thing. On the side of the expansion tank is a water hose. Make sure this guy is connected and if not, do not let it drip down because it will drain your coolant! At the minimum, make sure that this hose is placed upward so that any water momentum is reduced and so is the reduction in the level of your expansion tank. If you think you are losing coolant, just place a piece of cardboard underneath and turn over the car for a few minutes and pull it out. If it's clean, you have no leaks. My cardboard was dry, dry, dry.
I found this out all by accident and with my meter and a lot of attitude. My car runs cool now! SMASHING!
Charlane _________________ Electra is Here......
One 1980 924 Turbo
One 1990 KZ1000P (CHPS) Motorcycle
One 1984 244 Turbo Volvo (B21FT) (I installed this engine myself)
One 1977 240D Mercedes Benz
One 1970 Chevy Impala |
Posted: Tue Jul 18, 2006 12:58 am Post subject: |
| Charlane wrote: | | If you are pulling less than 13 volts, consider increasing your throttle to increase the action from your alternator which translates into your electrical cooling! |
rasta |
-nick
Posted: Tue Jul 18, 2006 5:29 am Post subject: |
In addition to replacing the t-stat, make sure you have a solid ground from the battery neg to the body, and from the body to the engine. I left my battery-body earth loose and my temp gauge was reading at the 3/4 + mark when it was actually at a perfect 180F (around the 1/4 mark on the gauge). Tightened the earth, and it read correctly.
ps- contrary to Charlane's notes, the coolant system is sealed. Leaving the small reservoir-to-radiator hose off is like leaving the reservoir cap off. The system won't build pressure. |
Slam
Posted: Tue Jul 18, 2006 8:02 am Post subject: |
A couple of quick checks: get a stethoscope and listen to the water pump with then engine running. If it's on its way out, you'll hear it. Plus, there's a weep hole on the underside of it. Check there for coolant seepage. The pump is easy to replace if it is dying.
If the rad doesn't leak, give it a good flush. It's easy to take out and any rad shop can pressure test it for you if you want to go that route.
I'd agree about the thermostat issue, and add one thing. Make sure the rad cap is OEM. Using the OEM rad cap can save lots of chasing when it comes to diagnosing overheating. _________________ '88 944 Auto - may or may not resurrect |
D Hook
Posted: Tue Jul 18, 2006 9:52 am Post subject: |
WOW! This thread is a year old. Never heard from the OP if he solved the problem. Can only assume he did. _________________ '80 924 n/a SOLD |
seanski44
Joined: 13 Mar 2006 Posts: 532 Location: Nottingham UK
Posted: Tue Jul 18, 2006 9:10 pm Post subject: |
| D Hook wrote: | | WOW! This thread is a year old. Never heard from the OP if he solved the problem. Can only assume he did. |
maybe he shipped out.... _________________ 1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD |
