AFRICA DEE
Joined: 16 May 2006 Posts: 48 Location: JOHANNESBURG, SOUTH AFRICA
Posted: Fri Jul 07, 2006 8:24 pm Post subject: WHICH PRESSURE PLATE WITH FORD BRONCO II CLUTCH PLATE |
I don't know if this has been covered, but which non-Porsche pressure plate goes with the Bronco plate?
And if there are options, which one is the better option in terms of track day use?? _________________ 1980 924 N/A Ex-931 Track car: My cash guzzler
2004 996 4S: My Weekend plaything
2012 VW POLO GT: My daily commuter |
Posted: Sat Jul 08, 2006 4:22 am Post subject: |
first off please refrain from using caps lock, on the net it indicates yelling,
so when posting a topic or a responce just use lower case.
as per the pressure plate, the only one you can use is the porsche one, no others fit, just the clutch disc has others that work. _________________ 3 928s, |
