pyromjm
Joined: 26 Sep 2003 Posts: 154 Location: Cupertino, CA USA
Posted: Fri Jun 30, 2006 9:21 am Post subject: Front Control arm front pivot bolt STUCK |
I can NOT remove the bolt that runs through the pivot on the front right control arm, front mount. i have the nut off and the bolt seems to have become ONE with the bushing or something as it will not twist independently from the control arm pivoting. i have pounded the end of the bolt with a rod and hammer it is not budging. i am so pissed off at my car right now
-mike _________________ 1982 924 NA gray/silver with black int. |
Posted: Fri Jun 30, 2006 10:59 am Post subject: |
Being careful not to burn anything else, heat the bolt until the rubber starts to smoke, then drive it out with a BF hammer and punch. _________________ White 87 924S "Ghost"
pyromjm
Posted: Fri Jun 30, 2006 1:29 pm Post subject: |
Thanks for the suggestion paul, ill give that a shot _________________ 1982 924 NA gray/silver with black int. |
Posted: Fri Jun 30, 2006 10:14 pm Post subject: |
The bolt is probably rusted to the steel sleeve inner liner of the bushing... _________________ Vaughan Scott
pyromjm
Posted: Sat Jul 01, 2006 1:33 am Post subject: |
What should i do in that case?
grind it off and buy a new control arm _________________ 1982 924 NA gray/silver with black int. |
Posted: Sat Jul 01, 2006 2:00 am Post subject: |
Might be the easiest if you have access to a die grinder. At least buy a new bolt - just press out and replace the bushing, not necessarily requiring a new arm... _________________ Vaughan Scott
pyromjm
Posted: Mon Jul 03, 2006 7:11 am Post subject: |
Ground off the ends of the bolt ( which took FOREVER) and dropped it out of the mount on the crossmember. man that bolt would NOT come out, ended up pressing out the whole bushing with the bolt still in it. Ordered a whole new set of a-arm bushings online things cost over 80 bucks!
Posted: Mon Jul 03, 2006 8:49 am Post subject: |
I trust that was both sides?? _________________ Vaughan Scott
pyromjm
Posted: Tue Jul 04, 2006 6:37 am Post subject: |
yea it was for a set of 4 bushings, two for each side
Have a wonderful day today and the rest of your lives. remember, "Live happy, Live healthy, and live longs"! Longs Drugs _________________ 1982 924 NA gray/silver with black int. |
